I do have some experience but I’ve never built a circuit, always just theory in first year electrical. I want to add lighting to a Lego Sydney opera house that is on display, i want to light the 3 large shades and was hoping to run some sort of a led string running underneath the “lamp posts” running around the outside (I’d like these ones to be duller).
As i said I haven’t done much practical work but I was hoping to run the system off a 6v source of 4xAA batteries. I haven’t worked much with mcd as a measure of brightness so i still don’t know the comparative brightness levels either. What i was thinking was 2 LED’s per large shade (one at each end) and one smaller one for the smaller shade, or one bright one per shade if it does the same job. I was looking at White Cool LEDS with a Vf of 3.2v but obviously 6v doesn’t equal 6.4v. I’m not sure of the difference between a cool white and a yellow led but i was considering a yellow led with a Vf of 2v. However this still left me wondering about the light string i wanted to run around the base of the construction to light the “lamps” (they’re hollow lego posts with a clear bit on the top and a small hole drilled through the base plate).
What sort of mcd should i use for this project and am I able to power the whole project from one 6v source? Any and all help or suggestion to turn this practical will be much appreciated ![]()
