Nintendo Switch Macro Recording Project
I’m new to the forums, so I hope this is the right place.
I’m having trouble with this project in OS setup.
When I do the command: sudo apt install python3-dbus libhidapi-hidraw0 keyboard
I get this error:
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package keyboard
I found in preferences<add/remove programs<Programming the libhidapi library and applied it. Do I need to do anything else to install it because it’s still giving me that error? or am I missing something else?
Any help/guidance would be appreciated. Thanks!
Hey, you actually found a mistake in the instructions, so thanks for posting! I updated the tutorial with the right commands, but I think all you need to do to get up and running is open a terminal on your Pi and run this command:
sudo pip3 install keyboard
I think that should do the trick!
