Hi there.
I am trying to make my own makefile and I start easy but I don’t get it to work.
What is wrong with this code?
CC = arm-elf-gcc
all: main.o
.PHONY: all
main.o: .src\main.c
$(CC) .src\main.c
The error:
make -k all
make: *** No rule to make target .src\main.c', needed by main.o’.
make: Target `all’ not remade because of errors.
I am using eclipse as a platform.
Raymond
I think it complains because it cannot find src\main.c, therefore it looks for a rule to create it, but it cannot find such a rule.
Most likely is that make is confused by the backslash, try src/main.c instead of src\main.c
make -k all
make: *** No rule to make target .src/main.c', needed by main.o’.
Raymond
Are you sure that the make can find your compiler? Check to make sure that the directory that arm-elf-gcc is in is in your environmnent varables somewhere.
If I open a commandprompt and goes to that directory and type:
arm-elf-gcc src\main.c
A file a.out is created in my directory.
I guess that since that works it is in my environment variable.
Raymond
D’oh!
Obviously the dot. What was the intention of that anyway?
I am a new user of the opensource and ARM, so mostly I try to copy and modify things that works.
One eye on the project and one on the manuals.
The reason the dot was copied (the intention) was that “yagarto” had it in his makefile in a small project called STR7Test.
STR7Test->makefile
List C source files here
SRC = ./src/main.c
I don’t know why it works with that project and not with mine yet, but I will find out.
Thanks for your help
Raymond
./ means the current directory, while .src\ means a file with the name ".src", i.e. you missed the slash after the dot.
Regards,
Dominic
