No Wav Trigger output at first power up after long down time.
I could successfully make my Wav Trigger play files from my 16GB SD Card.
If I remove 12V power and don’t plug it back in for any duration longer than 2mins, it won’t play audio from speakers (instead I hear longer electronic noise/beep from the board). After this, if I unplug and plug it back in, the audio works fine.
Try enabling Audio Amp Power https://cdn.sparkfun.com/assets/1/c/9/a … 230114.pdf
