In my S3C2440 board, I use openocd to load a bin file to the internal RAM, and run it.
I found:
- I initialize the SDRAM controller, disable the Icache, and then copy the code to SDRAM, jump to SDRAM.
The program can’t run ok. But if I enable the Icache, every thing is ok.
- In anothre program, I use openocd to load it to the internal RAM, and run it. It does not run in SDRAM yet.
It has this instruction :
" halt_loop:
b halt_loop "
When I enabel ICache, a error will occur in openocd:
invalid mode value encountered
cpsr contains invalid mode value - communication failure
But If I disable ICache, it is ok: I halt it ,and its PC is alway point to the “halt_loop” .
So, if I want to run in SDRAM, I have to enable ICache; but if I enable ICache, some errors such as “invalid mode value encountered cpsr contains invalid mode value - communication failure” may occur.
I don’t know why.
My english is poor, I home you can understand me.
