NOTE: Version 2.0 of the SparkFun Qwiic Acconeer XM125 library requires a code change
I just wanted to note that the just released 2.0 upgrade to the SparkFun Qwiic Acconeer XM125 library will require a minor code change – renaming the Sensor Object being used.
More details on what is required outlined here. The TL;DR - you need to change the sensor classname .
The change was made to simplify the library, resulting in something easier to use and maintain. It also makes it straightforward to add additional application support in the future.
If there any questions or issues - let us know/reply here.
-Kirk
