I have a nrf5280 based board. I have been reading on the various codes/libraries for a few days now.
I understand the main issue I’m facing is the 64mhz speed of the nrf52840 is a bit fast for the hx711. I think this may be affecting the power up/down sequence or the get data command.
Using the Arduino supplied library from Bodge, it seems as though the code is completely skipping the void setup() portion.
At this point I would like to find some information on if these two products are compatible and what I will need to start learning in order to get them functioning together.
Thank you!
