Hi, I am using LPC 2378 ARM microcontroller for displaying characters based on NTSC output on a TV. Are there any libraries available for it.
Plz help I am in urgent need. Thanks…
I have got libraries for AVR…but have no clue how to convert them for ARM.
ANy clues about it. following is the code for AVR
// Black and white NTSC video generation with fixed point animation
// D.6 is sync:330 ohm + diode to 75 ohm resistor
// D.5 is video:1000 ohm + diode to 75 ohm resistor
// Mega644 version by Shane Pryor 142h x 200v resolution
// mods by brl4@cornell.edu
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#include <math.h>
#include <util/delay.h>
#include <avr/sleep.h>
// optional, if preferred///
//#define begin {
//#define end }
//cycles = 63.55 * 20 Note NTSC is 63.55
//but this line duration makes each frame exactly 1/60 sec
//which is nice for keeping a realtime clock
#define lineTime 1271
#define ScreenTop 30
#define ScreenBot 230
//sync
char syncON, syncOFF;
//current line number in the current frame
volatile int LineCount;
//200 x 144 - screen buffer and pointer
char screen[3600];
int* screenindex;
//One bit masks
char pos[8] = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
//3x5 font numbers, then letters
//packed two per definition for fast
//copy to the screen at x-position divisible by 4
prog_char smallbitmap[39][5] = {
//0
0b11101110,
0b10101010,
0b10101010,
0b10101010,
0b11101110,
//1
0b01000100,
0b11001100,
0b01000100,
0b01000100,
0b11101110,
//2
0b11101110,
0b00100010,
0b11101110,
0b10001000,
0b11101110,
//3
0b11101110,
0b00100010,
0b11101110,
0b00100010,
0b11101110,
//4
0b10101010,
0b10101010,
0b11101110,
0b00100010,
0b00100010,
//5
0b11101110,
0b10001000,
0b11101110,
0b00100010,
0b11101110,
//6
0b11001100,
0b10001000,
0b11101110,
0b10101010,
0b11101110,
//7
0b11101110,
0b00100010,
0b01000100,
0b10001000,
0b10001000,
//8
0b11101110,
0b10101010,
0b11101110,
0b10101010,
0b11101110,
//9
0b11101110,
0b10101010,
0b11101110,
0b00100010,
0b01100110,
0b00000000,
0b01000100,
0b00000000,
0b01000100,
0b00000000,
0b00000000,
0b11101110,
0b00000000,
0b11101110,
0b00000000,
//blank
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//A
0b11101110,
0b10101010,
0b11101110,
0b10101010,
0b10101010,
//B
0b11001100,
0b10101010,
0b11101110,
0b10101010,
0b11001100,
//C
0b11101110,
0b10001000,
0b10001000,
0b10001000,
0b11101110,
//D
0b11001100,
0b10101010,
0b10101010,
0b10101010,
0b11001100,
//E
0b11101110,
0b10001000,
0b11101110,
0b10001000,
0b11101110,
//F
0b11101110,
0b10001000,
0b11101110,
0b10001000,
0b10001000,
//G
0b11101110,
0b10001000,
0b10001000,
0b10101010,
0b11101110,
//H
0b10101010,
0b10101010,
0b11101110,
0b10101010,
0b10101010,
//I
0b11101110,
0b01000100,
0b01000100,
0b01000100,
0b11101110,
//J
0b00100010,
0b00100010,
0b00100010,
0b10101010,
0b11101110,
//K
0b10001000,
0b10101010,
0b11001100,
0b11001100,
0b10101010,
//L
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b11101110,
//M
0b10101010,
0b11101110,
0b11101110,
0b10101010,
0b10101010,
//N
0b00000000,
0b11001100,
0b10101010,
0b10101010,
0b10101010,
//O
0b01000100,
0b10101010,
0b10101010,
0b10101010,
0b01000100,
//P
0b11101110,
0b10101010,
0b11101110,
0b10001000,
0b10001000,
//Q
0b01000100,
0b10101010,
0b10101010,
0b11101110,
0b01100110,
//R
0b11101110,
0b10101010,
0b11001100,
0b11101110,
0b10101010,
//S
0b11101110,
0b10001000,
0b11101110,
0b00100010,
0b11101110,
//T
0b11101110,
0b01000100,
0b01000100,
0b01000100,
0b01000100,
//U
0b10101010,
0b10101010,
0b10101010,
0b10101010,
0b11101110,
//V
0b10101010,
0b10101010,
0b10101010,
0b10101010,
0b01000100,
//W
0b10101010,
0b10101010,
0b11101110,
0b11101110,
0b10101010,
//X
0b00000000,
0b10101010,
0b01000100,
0b01000100,
0b10101010,
//Y
0b10101010,
0b10101010,
0b01000100,
0b01000100,
0b01000100,
//Z
0b11101110,
0b00100010,
0b01000100,
0b10001000,
0b11101110
// Full ascii 5x7 char set
// Designed by: David Perez de la Cruz,and Ed Lau
// see: http://instruct1.cit.cornell.edu/course … index.html
prog_char ascii[128][7] = {
//0
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//1
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//2
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//3
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//4
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//5
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//6
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//7
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//8
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//9
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//10
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//11
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//12
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//13
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//14
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//15
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//16
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//17
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//18
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//19
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//20
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//21
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//22
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//23
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//24
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//25
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//26
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//27
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//28
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//29
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//30
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//31
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//32 Space
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//33 Exclamation !
0b01100000,
0b01100000,
0b01100000,
0b01100000,
0b00000000,
0b00000000,
0b01100000,
//34 Quotes "
0b01010000,
0b01010000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//35 Number #
0b00000000,
0b01010000,
0b11111000,
0b01010000,
0b11111000,
0b01010000,
0b00000000,
//36 Dollars $
0b01110000,
0b10100000,
0b10100000,
0b01110000,
0b00101000,
0b00101000,
0b01110000,
//37 Percent %
0b01000000,
0b10101000,
0b01010000,
0b00100000,
0b01010000,
0b10101000,
0b00010000,
//38 Ampersand &
0b00100000,
0b01010000,
0b10100000,
0b01000000,
0b10101000,
0b10010000,
0b01101000,
//39 Single Quote ’
0b01000000,
0b01000000,
0b01000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//40 Left Parenthesis (
0b00010000,
0b00100000,
0b01000000,
0b01000000,
0b01000000,
0b00100000,
0b00010000,
//41 Right Parenthesis )
0b01000000,
0b00100000,
0b00010000,
0b00010000,
0b00010000,
0b00100000,
0b01000000,
//42 Star *
0b00010000,
0b00111000,
0b00010000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//43 Plus +
0b00000000,
0b00100000,
0b00100000,
0b11111000,
0b00100000,
0b00100000,
0b00000000,
//44 Comma ,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00010000,
0b00010000,
//45 Minus -
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b11111000,
0b00000000,
0b00000000,
//46 Period .
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00010000,
// 47 Backslash /
0b00000000,
0b00001000,
0b00010000,
0b00100000,
0b01000000,
0b10000000,
0b00000000,
// 48 Zero
0b01110000,
0b10001000,
0b10011000,
0b10101000,
0b11001000,
0b10001000,
0b01110000,
//49 One
0b00100000,
0b01100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b01110000,
//50 two
0b01110000,
0b10001000,
0b00001000,
0b00010000,
0b00100000,
0b01000000,
0b11111000,
//51 Three
0b11111000,
0b00010000,
0b00100000,
0b00010000,
0b00001000,
0b10001000,
0b01110000,
//52 Four
0b00010000,
0b00110000,
0b01010000,
0b10010000,
0b11111000,
0b00010000,
0b00010000,
//53 Five
0b11111000,
0b10000000,
0b11110000,
0b00001000,
0b00001000,
0b10001000,
0b01110000,
//54 Six
0b01000000,
0b10000000,
0b10000000,
0b11110000,
0b10001000,
0b10001000,
0b01110000,
//55 Seven
0b11111000,
0b00001000,
0b00010000,
0b00100000,
0b01000000,
0b10000000,
0b10000000,
//56 Eight
0b01110000,
0b10001000,
0b10001000,
0b01110000,
0b10001000,
0b10001000,
0b01110000,
//57 Nine
0b01110000,
0b10001000,
0b10001000,
0b01111000,
0b00001000,
0b00001000,
0b00010000,
//58 :
0b00000000,
0b00000000,
0b00100000,
0b00000000,
0b00000000,
0b00000000,
0b00100000,
//59 ;
0b00000000,
0b00000000,
0b00100000,
0b00000000,
0b00000000,
0b00100000,
0b00100000,
//60 <
0b00000000,
0b00011000,
0b01100000,
0b10000000,
0b01100000,
0b00011000,
0b00000000,
//61 =
0b00000000,
0b00000000,
0b01111000,
0b00000000,
0b01111000,
0b00000000,
0b00000000,
//62 >
0b00000000,
0b11000000,
0b00110000,
0b00001000,
0b00110000,
0b11000000,
0b00000000,
//63 ?
0b00110000,
0b01001000,
0b00010000,
0b00100000,
0b00100000,
0b00000000,
0b00100000,
//64 @
0b01110000,
0b10001000,
0b10111000,
0b10101000,
0b10010000,
0b10001000,
0b01110000,
//65 A
0b01110000,
0b10001000,
0b10001000,
0b10001000,
0b11111000,
0b10001000,
0b10001000,
//B
0b11110000,
0b10001000,
0b10001000,
0b11110000,
0b10001000,
0b10001000,
0b11110000,
//C
0b01110000,
0b10001000,
0b10000000,
0b10000000,
0b10000000,
0b10001000,
0b01110000,
//D
0b11110000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b11110000,
//E
0b11111000,
0b10000000,
0b10000000,
0b11111000,
0b10000000,
0b10000000,
0b11111000,
//F
0b11111000,
0b10000000,
0b10000000,
0b11111000,
0b10000000,
0b10000000,
0b10000000,
//G
0b01110000,
0b10001000,
0b10000000,
0b10011000,
0b10001000,
0b10001000,
0b01110000,
//H
0b10001000,
0b10001000,
0b10001000,
0b11111000,
0b10001000,
0b10001000,
0b10001000,
//I
0b01110000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b01110000,
//J
0b00111000,
0b00010000,
0b00010000,
0b00010000,
0b00010000,
0b10010000,
0b01100000,
//K
0b10001000,
0b10010000,
0b10100000,
0b11000000,
0b10100000,
0b10010000,
0b10001000,
//L
0b10000000,
0b10000000,
0b10000000,
0b10000000,
0b10000000,
0b10000000,
0b11111000,
//M
0b10001000,
0b11011000,
0b10101000,
0b10101000,
0b10001000,
0b10001000,
0b10001000,
//N
0b10001000,
0b10001000,
0b11001000,
0b10101000,
0b10011000,
0b10001000,
0b10001000,
//O
0b01110000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b01110000,
//P
0b11110000,
0b10001000,
0b10001000,
0b11110000,
0b10000000,
0b10000000,
0b10000000,
//Q
0b01110000,
0b10001000,
0b10001000,
0b10001000,
0b10101000,
0b10010000,
0b01101000,
//R
0b11110000,
0b10001000,
0b10001000,
0b11110000,
0b10100000,
0b10010000,
0b10001000,
//S
0b01111000,
0b10000000,
0b10000000,
0b01110000,
0b00001000,
0b00001000,
0b11110000,
//T
0b11111000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
//U
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b01110000,
//V
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b10001000,
0b01010000,
0b00100000,
//W
0b10001000,
0b10001000,
0b10001000,
0b10101000,
0b10101000,
0b10101000,
0b01010000,
//X
0b10001000,
0b10001000,
0b01010000,
0b00100000,
0b01010000,
0b10001000,
0b10001000,
//Y
0b10001000,
0b10001000,
0b10001000,
0b01010000,
0b00100000,
0b00100000,
0b00100000,
//Z
0b11111000,
0b00001000,
0b00010000,
0b00100000,
0b01000000,
0b10000000,
0b11111000,
//91 [
0b11100000,
0b10000000,
0b10000000,
0b10000000,
0b10000000,
0b10000000,
0b11100000,
//92 (backslash)
0b00000000,
0b10000000,
0b01000000,
0b00100000,
0b00010000,
0b00001000,
0b00000000,
//93 ]
0b00111000,
0b00001000,
0b00001000,
0b00001000,
0b00001000,
0b00001000,
0b00111000,
//94 ^
0b00100000,
0b01010000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//95 _
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b11111000,
//96 `
0b10000000,
0b01000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
//97 a
0b00000000,
0b01100000,
0b00010000,
0b01110000,
0b10010000,
0b01100000,
0b00000000,
//98 b
0b10000000,
0b10000000,
0b11100000,
0b10010000,
0b10010000,
0b11100000,
0b00000000,
//99 c
0b00000000,
0b00000000,
0b01110000,
0b10000000,
0b10000000,
0b01110000,
0b00000000,
// 100 d
0b00010000,
0b00010000,
0b01110000,
0b10010000,
0b10010000,
0b01110000,
0b00000000,
//101 e
0b00000000,
0b01100000,
0b10010000,
0b11110000,
0b10000000,
0b01110000,
0b00000000,
//102 f
0b00110000,
0b01000000,
0b11100000,
0b01000000,
0b01000000,
0b01000000,
0b00000000,
//103 g
0b00000000,
0b01100000,
0b10010000,
0b01110000,
0b00010000,
0b00010000,
0b01100000,
//104 h
0b10000000,
0b10000000,
0b11100000,
0b10010000,
0b10010000,
0b10010000,
0b00000000,
//105 i
0b00000000,
0b00100000,
0b00000000,
0b00100000,
0b00100000,
0b00100000,
0b00000000,
//106 j
0b00000000,
0b00010000,
0b00000000,
0b00010000,
0b00010000,
0b00010000,
0b01100000,
//107 k
0b10000000,
0b10010000,
0b10100000,
0b11000000,
0b10100000,
0b10010000,
0b00000000,
//108 l
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00000000,
//109 m
0b00000000,
0b00000000,
0b01010000,
0b10101000,
0b10101000,
0b10101000,
0b00000000,
//110 n
0b00000000,
0b00000000,
0b01100000,
0b10010000,
0b10010000,
0b10010000,
0b00000000,
//111 o
0b00000000,
0b00000000,
0b01100000,
0b10010000,
0b10010000,
0b01100000,
0b00000000,
//112 p
0b00000000,
0b00000000,
0b01100000,
0b10010000,
0b11110000,
0b10000000,
0b10000000,
//113 q
0b00000000,
0b00000000,
0b01100000,
0b10010000,
0b11110000,
0b00010000,
0b00010000,
//114 r
0b00000000,
0b00000000,
0b10111000,
0b01000000,
0b01000000,
0b01000000,
0b00000000,
//115 s
0b00000000,
0b00000000,
0b01110000,
0b01000000,
0b00010000,
0b01110000,
0b00000000,
//116 t
0b01000000,
0b01000000,
0b11100000,
0b01000000,
0b01000000,
0b01000000,
0b00000000,
// 117u
0b00000000,
0b00000000,
0b10010000,
0b10010000,
0b10010000,
0b01100000,
0b00000000,
//118 v
0b00000000,
0b00000000,
0b10001000,
0b10001000,
0b01010000,
0b00100000,
0b00000000,
//119 w
0b00000000,
0b00000000,
0b10101000,
0b10101000,
0b01010000,
0b01010000,
0b00000000,
//120 x
0b00000000,
0b00000000,
0b10010000,
0b01100000,
0b01100000,
0b10010000,
0b00000000,
//121 y
0b00000000,
0b00000000,
0b10010000,
0b10010000,
0b01100000,
0b01000000,
0b10000000,
//122 z
0b00000000,
0b00000000,
0b11110000,
0b00100000,
0b01000000,
0b11110000,
0b00000000,
//123 {
0b00100000,
0b01000000,
0b01000000,
0b10000000,
0b01000000,
0b01000000,
0b00100000,
//124 |
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
0b00100000,
//125 }
0b00100000,
0b00010000,
0b00010000,
0b00001000,
0b00010000,
0b00010000,
0b00100000,
//126 ~
0b00000000,
0b00000000,
0b01000000,
0b10101000,
0b00010000,
0b00000000,
0b00000000,
//127 DEL
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000,
0b00000000
//macro to put a byte to the screen
asm(“.MACRO videobits\n\t”
“BST R4,7\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,6\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,5\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,4\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,3\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,2\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,1\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“NOP \n\t”
“NOP \n\t”
“BST R4,0\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
“.ENDM\n\t”
// puts 18 bytes (1 line) to the screen
void byteblast() {
asm(“LDS R26,screenindex\n\t”
“LDS R27,screenindex+1\n\t”
“LDI R30, 0x40\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X+\n\t”
“videobits\n\t”
“LD R4,X\n\t”
“videobits\n\t”
“CLT\n\t”
“LDI R30, 0x40\n\t”
“BLD R30,5\n\t”
“OUT 0x0b,R30\n\t”
//This is the sync generator and raster generator. It MUST be entered from
//sleep mode to get accurate timing of the sync pulses
ISR (TIMER1_COMPA_vect) {
//start the Horizontal sync pulse
PORTD = syncON;
//update the current scanline number
LineCount++;
//begin inverted (Vertical) synch after line 247
if (LineCount==248) {
syncON = 0b01000000;
syncOFF = 0;
//back to regular sync after line 250
if (LineCount==251) {
syncON = 0;
syncOFF = 0b01000000;
//start new frame after line 262
if (LineCount==263)
LineCount = 1;
//adjust to make 5 us pulses
_delay_us(2);
//end sync pulse
PORTD = syncOFF;
if (LineCount < ScreenBot && LineCount >= ScreenTop) {
//compute offset into screen array
screenindex = screen + ((LineCount - ScreenTop) << 4) + ((LineCount - ScreenTop) << 1);
//center image on screen
_delay_us(11); //12
//blast the data to the screen
byteblast();
//plot one point
//at x,y with color 1=white 0=black 2=invert
void video_pt(char x, char y, char c) {
//each line has 18 bytes
//calculate i based upon this and x,y
// the byte with the pixel in it
int i = (x >> 3) + ((int)y<<4) + ((int)y<<1);
if (c==1)
screen = screen | pos[x & 7];
else if (c==0)
screen = screen & ~pos[x & 7];
else
screen = screen ^ pos[x & 7];
//plot a line
//at x1,y1 to x2,y2 with color 1=white 0=black 2=invert
//NOTE: this function requires signed chars
//Code is from David Rodgers,
//“Procedural Elements of Computer Graphics”,1985
void video_line(char x1, char y1, char x2, char y2, char c) {
* int e;*
* signed int dx,dy,j, temp;*
* signed char s1,s2, xchange;*
signed int x,y;
* x = x1;*
* y = y1;*
* //take absolute value*
* if (x2 < x1) {*
* dx = x1 - x2;*
* s1 = -1;*
* else if (x2 == x1) {*
* dx = 0;*
* s1 = 0;*
* else {*
* dx = x2 - x1;*
* s1 = 1;*
* if (y2 < y1) {*
* dy = y1 - y2;*
* s2 = -1;*
* else if (y2 == y1) {*
* dy = 0;*
* s2 = 0;*
* else {*
* dy = y2 - y1;*
* s2 = 1;*
* xchange = 0;*
* if (dy>dx) {*
* temp = dx;*
* dx = dy;*
* dy = temp;*
* xchange = 1;*
* e = ((int)dy<<1) - dx;*
* for (j=0; j<=dx; j++) {*
* video_pt(x,y,c);*
* if (e>=0) {*
* if (xchange==1) x = x + s1;*
* else y = y + s2;*
* e = e - ((int)dx<<1);*
* if (xchange==1) y = y + s2;*
* else x = x + s1;*
* e = e + ((int)dy<<1);*
// put a big character on the screen
// c is index into bitmap
void video_putchar(char x, char y, char c) {
char i;
* char y_pos;
uint8_t j;
_ for (i=0;i<7;i++) {_
y_pos = y + i;
j = pgm_read_byte(((uint32_t)(ascii)) + c7 + i);
video_pt(x, y_pos, (j & 0x80)==0x80);
video_pt(x+1, y_pos, (j & 0x40)==0x40);
video_pt(x+2, y_pos, (j & 0x20)==0x20);
video_pt(x+3, y_pos, (j & 0x10)==0x10);
video_pt(x+4, y_pos, (j & 0x08)==0x08);
// put a string of big characters on the screen
void video_puts(char x, char y, char str) {
_ char i;
for (i=0; str!=0; i++) {_
video_putchar(x,y,str);
_ x = x+6;
}*_
// put a small character on the screen
// x-coord must be on divisible by 4
void video_smallchar(char x, char y, char c) {
* char mask;*
* int i=((int)x>>3) + ((int)y<<4) + (((int)y)<<1);*
* if (x == (x & 0xf8)) mask = 0x0f; //f8*
* else mask = 0xf0;*
uint8_t j = pgm_read_byte(((uint32_t)(smallbitmap)) + c5);
screen = (screen & mask) | (j & ~mask);
j = pgm_read_byte(((uint32_t)(smallbitmap)) + c5 + 1);
* screen[i+18] = (screen[i+18] & mask) | (j & ~mask);*
j = pgm_read_byte(((uint32_t)(smallbitmap)) + c*5 + 2);
screen[i+36] = (screen[i+36] & mask) | (j & ~mask);
j = pgm_read_byte(((uint32_t)(smallbitmap)) + c5 + 3);
_ screen[i+54] = (screen[i+54] & mask) | (j & ~mask);*_
j = pgm_read_byte(((uint32_t)(smallbitmap)) + c5 + 4);
_ screen[i+72] = (screen[i+72] & mask) | (j & ~mask);
// put a string of small characters on the screen*
// x-cood must be on divisible by 4
void video_putsmalls(char x, char y, char *str) {
* char i;
x = x & 0b1111100; //make it divisible by 4*
for (i = 0; str != 0; i++) {
if (str >= 0x30 && str <= 0x3a)
video_smallchar(x, y, str - 0x30);
else video_smallchar(x, y, str*-0x40+12);*
* x += 4;
//return the value of one point*
char video_set(char x, char y) {
* //The following construction*
* //detects exactly one bit at the x,y location*
* int i = (x>>3) + ((int)y<<4) + ((int)y<<1);
return (screen *& 1<<(7-(x & 0x7))); *
//=== fixed point mult ===============================
int multfix(int a, int b) {
int result1 = a * b;
int result2 = (a>>8) * (b>>8);
return (result2 << 8) | (result1 >> 8);
//=== fixed conversion macros =========================================
#define int2fix(a) (((int)(a))<<8) //Convert char to fix. a is a char*
#define fix2int(a) ((signed char)((a)>>8)) //Convert fix to int. a is an int
#define float2fix(a) ((int)((a)256.0)) //Convert float to fix. a is a float_
_#define fix2float(a) (((float)(a))/256.0) //Convert fix to float. a is an int*
//=== animation stuff ==================================================
unsigned int x, y;
int vx, vy, g, drag;
char cu1[]=“Cornell ECE 4760”;
char cu2[]=“COPYRIGHT:2008”;
// set up the ports and timers
int main() {
//init timer 1 to generate sync
OCR1A = lineTime; //One NTSC line_
TCCR1B = 0x09; //full speed; clear-on-match
TCCR1A = 0x00; //turn off pwm and oc lines
TIMSK1 = 0x02; //enable interrupt T1 cmp A
//init ports
DDRD = 0xf0; //video out
DDRB = 0x00; //switches
DDRA = 0xff; //LEDs
//initialize synch constants
LineCount = 1;
syncON = 0b00000000;
//Print “CORNELL” message
video_puts(13,2,cu1);
//Print “Copyright” message
video_putsmalls(86,192,cu2);
//side lines
#define width 142
#define height 199
video_line(0,0,0,height,1);
video_line(width,0,width,height,1);
video_line(0,10,width,10,1);
video_line(0,0,width,0,1);
video_line(0,height,width,height,1);
//video_line(0,0,width,height,1); // tst diagonal
//init animation
// initial position
x = int2fix(20);
y = int2fix(40);
// initial velocity
vx = float2fix(2.5);
vy = float2fix(0.0);
// gravity and drag
g = float2fix(0.03);
drag = float2fix(0.004);
video_pt(fix2int(x),fix2int(y),2);
// Set up single video line timing
sei();
set_sleep_mode(SLEEP_MODE_IDLE);
sleep_enable();
//The following loop executes once/video line during lines
//1-230, then does all of the frame-end processing
for(;
//stall here until next line starts
//use sleep to make entry into sync ISR uniform time
* sleep_cpu();
_ //The following code executes during the vertical blanking*
//Code here can be as long as
//a total of 60 lines x 63.5 uSec/line x 8 cycles/uSec_
* if (LineCount == 231) {*
//animation
* //erase old ball using XOR mode*
// new vel = old vel + acceleration*dt (dt=1)
vy = vy + g - multfix(drag,vy);
vx = vx - multfix(drag,vx);
_ // new pos = old pos + velocity*dt (dt=1)
x = x + vx;
y = y + vy;_
* // Bounds check – fixed notation*
* if (x>0x8d00) { vx = -vx; x=0x8d00; } // right edge*
if (x<0x0100) { vx = -vx; x=0x0100; } // left edge
if (y>0xc600) { vy = -vy; y=0xc600; } // bottom edge
* video_pt(fix2int(x),fix2int(y),2);*
} //line 231
} //for
} //main
Has Anybody done NTSC for TV…??? Plz help
I don’t think that the outputs aren’t fast enough to do it in software. A Parallax Propeller is what I’d use.
I am using ARM LPC 2378 Bluescreen for it…It has CCLK =48 Mhz, and PCLK of 17.142 Mhz
with a PLL capacity of 480 Mhz…i believe It is quite fast enough …and could be done…
I just have to find a way…
Check the I/O speed, I don’t think it’s any faster than an AVR.
Read this and then compare with any AVR…
http://ics.nxp.com/products/lpc2000/lpc23xx/~LPC2368/
Plz help me if you know how to write the library routines for LPC2378 for NTSC protocol…Leave the rest things…
The I/O speed it rather slow. That’s why no one uses them for video generation.
Which speed are you talking about…Plz help…
If the base is wrong I cannot proceed further…
provide some link…so that i could get a better picture…
Have a look at the AMBA spec:
http://polimage.polito.it/~lavagno/esd/ … A_SPEC.pdf
I think that the AHB speed is the reason why no one seems to have implemented video on the ARM7. You might be able to display characters, of course.
Could you please tell what should I read from this…I am a student and its very difficult for me to understand the whole of it…
VGA signals seems easier to generate. Check this site http://www.pbjtech.com/
Angelo
I have tried to generate 1 us delay routine…with TIMER0 interrupt by this code…for NTSC protocol…the code i used is…
__irq void T0_IRQHandler (void) //use timer0 as system timer tick
time_1us_cnt++;
time_1us_flag = 1;
if (time_1us_cnt >= 1000)
time_1ms_cnt++;
time_1ms_flag = 1;
//time_1ms_cnt++;
//time_1ms_flag = 1;
if (time_1ms_cnt >= 10)
time_1ms_cnt = 0;
time_10ms_cnt++;
time_10ms_flag = 1;
if (time_10ms_cnt >= 10)
time_10ms_cnt = 0;
time_100ms_cnt++;
time_100ms_flag = 1;
if (time_100ms_cnt >= 5)
time_100ms_cnt = 0;
time_500ms_cnt++;
time_500ms_flag = 1;
T0IR = 1; //Clear interrupt flag
VICVectAddr = 0; //Acknowledge Interrupt
void timer_task(void)
if (time_1us_flag)
AppTask1us();
time_1us_flag = 0;
if (time_1ms_flag)
AppTask1ms();
time_1ms_flag = 0;
if (time_10ms_flag)
AppTask10ms();
time_10ms_flag = 0;
if (time_100ms_flag)
AppTask100ms();
time_100ms_flag = 0;
if (time_500ms_flag)
AppTask500ms();
time_500ms_flag = 0;
void timer_init(void)
//Enable and setup timer interrupt, start timer
T0MR0 = 17; /* 1msec = 17142 at 17.143 MHz ; 1usec= 17 at 17.143MHz*/
T0MCR = 3; /* Interrupt and Reset on MR0 */
T0TCR = 1; /* Timer0 Enable */
VICVectAddr4 = (unsigned long)T0_IRQHandler;/* Set Interrupt Vector */
VICVectCntl4 = 15; /* use it for Timer0 Interrupt */
VICIntEnable |= (1 << 4); /* Enable Timer0 Interrupt */
Is it correct…?? I am not able to generate the requiired delay…of 1 us
Some people do this with Assembly instructions…I dont know assembly…
If anybody could Help…plz reply…
Even VGA routines would be of great help…plz give a link containing some code how to do that…
Just my 2 cents.
I don’t know about NTSC, but on PAL video composite signal, colors are coded with a sinusoidal 4.43Mhz signal on top of B/W video signal. You will never reach such speeds to encode color video composite signal. That’s why VGA is used, each color has its own signal.
On PAL, one horizontal line is 64us. If you want to have a decent resolution to display chars, let say 640 dots as VGA for 80 char of 7+1 dot, it means 1 dot is 100ns. So your software should generate a signal of 10Mhz ![]()
And the 2 cents of my 2 cents :mrgreen: don’t waste your time trying to generate video compiste signal. Move to at least VGA and use a PC monitor. Or a TV with VGA input.
And Google is your friend: http://tinyvga.com/avr-vga Lot of assembly code there :?
Angelo
