Older Redboard EEPROM / NVM
Can anyone provide a definitive answer to if the following older versions of the classic Redboard have EEPROM / NVM, and if so, what the size and write cycles are?
DEV-13975 (aka v22)
DEV-12757 (aka v21)
Thanks in advance!
Theres 1kb of EEPROM inside the ATmega328 chip on both boards. Check the datasheet for more information.
Found this, might also be helpful to you!
