Olimex AVR-PG1 painfully slow with avrdude
Hey there,
Basically I have the setup from lecture #2 on the site, except I opted for the serial version of the programmer because I have no parallel or serial port on my computer and figured a usb to serial cable would be the best hope.
Well everything works, and I can program the ATMega168, however the problem is the speed at which it reads/writes a hex file from/to the flash memory. Currently I’m clocking in at about 4 bytes / second. That just seems ridiculously slow.
The USB to serial cable I have is here: http://www.pimfg.net/product_detail.asp … part=UN8BE
Does anyone have any ideas? I’d like to exhaust my options before I have to invest in another more expensive programmer. But 4 bytes per second is unbearably slow for development.
-Mike
I did a pretty extensive search and pretty much all that I could find that was even slightly related was this link (but not the same programmer): http://www.evilmadscientist.com/article … rmac/print
why don’t you try using it on a PC without the USB to serial connection first.
I am sure you can find someone with a serial port.
Digi-Key has the ATAVRISP2-ND for under $40.
This one works on a usb port.
Thanks for replying. Honestly I didn’t really do any research about a serial to USB cable and if it would work with the Olimex programmer, I just assumed there was a good chance it would, and it was a cheap solution. Believe it or not I don’t have immediately easy access to a PC with a serial port (seems wrong I know…).
Ultimately I guess I’m lucky it actually worked (Olimex says it won’t on further inspection), and at least it gave me something to play with while I learned initially. I’ve already ordered the AVRISP mkII from digikey. If I had not come to that conclusion on my own already you’re response would have been very helpful, so thanks anyhow.
Every program I have used with my USB to serial has ALWAYS had some kind of problem.
I used a USB<->serial converter with the serial programmer and found it to be slow as well.
I replaced it with this: http://www.ladyada.net/make/usbtinyisp/index.html, which seems to be several orders of magnitude faster.
I use it to program my various olimex boards and am happy with it.
