I found some sources and combined them for accessing the adc.
Somehow it delivers values, maybe anybody has some expiriances …
ADC Operation
1 To enable clocks for the ADC block, set the TSEN bit in the Syscon section (ADCClkDiv register).
2 Set the DeviceCfg.ADCEN bit.
3 Clear the DeviceCfg.ADCPD bit.
4 Select an input. First unlock the software lock by writing 0xAA to the ADCSWLock register.
Then write an appropriate value (selected from Table 20-2on page520) to the ADCSwitch register.
5 To poll, read the ADCResult register repeatedly. Bit 31 of this register is the SDR,
or Synchronous Data Ready, bit. This bit is set when a new valid conversion value appears in
this register and is cleared when this register is read.
So when two consecutive reads show the bit clear and then set, the second read has the new valid value.
6 Conversion data may also be processed using interrupts from this module. If bit 11 in the ADCIntEn register
(the RINTEN bit) is set, an interrupt occurs whenever the SDR bit in the ADCResult register is set.
Therefore, an interrupt handler can read the ADCResult register whenever a new valid sample appears
in the register, which both returns a new conversion value and clears the interrupt.
Register Memory Map
Address Name SW locked Type Size Description
0x8090_0000 Reserved
0x8090_0004 Reserved
0x8090_0008 ADCResult No Read Only 32 bits ADC result register.
0x8090_000C Reserved
0x8090_0010 Reserved
0x8090_0014 Reserved
0x8090_0018 ADCSwitch Write Read/Write 28 bits ADC Switch Matrix control register.
0x8090_001C Reserved
0x8090_0020 ADCSWLock NA Read/Write 1-bit read ADC software lock register.
8-bit write
0x8090_0024 ADCIntEn No Read/Write 9 bits ADC Interrupt Enable Register
0x8093_0090 ADCClkDiv Yes R/W 32 ADC Clock Divider
0x8093_0080 DeviceCfg Yes R/W 32 Device configuration
ADC result register: 0x8090_0008
Bit 31: SDR: Synchronous Data Ready
Bit 0-12: AD: Analog-to-digital converter output at 12-bit resolution
ADCSwitch: 0x8090_0018
Input to Measure ADC Switch Value
ADC4 0x0000_0610
ADC3 0x0000_0620
ADC2 0x0000_0640
ADC1 0x0000_0680
ADC0 0x0000_0608
ADCSWLock: 0x8090_0020
SWLCK Software lock bits
WRITE: The Unlock value for this feature is 0xAA
READ: During a read operation SWLCK[0] has the following meaning:
1 = Unlocked for current bus access.
0 = Locked
ADCIntEn: 0x8090_0024
RINTEN: Bit 11: Synchronous Data Ready Interrupt Enable. Setting this bit results in an
interrupt whenever the Synchronous Data Ready (SDR) bit in the ADCResult register is set.
ADCClkDiv: 0x8093_0090
ADCEN: Bit 31: ADC clock enable.
ADIV: Bit 16: ADC clock divider value.
0 - ADC Clock is divide-by-16 from the external oscillator.
1 - ADC Clock is divide-by-4 from the external oscillator.
DeviceCfg: 0x8093_0080
ADCPD: Bit 2: ADC Power Down.
1 - ADC and clocks are powered down.
0 - ADC and clocks are active. ADCPD must be zero for normal ADC operation.
ADCEN: Bit 17: ADC Enable.
The ADCEN bit does not affect the ADC power state.
ADC power down is directly controlled by the ADCPD bit.
1 = ADC Interface enabled.
0 = ADC Interface disabled.
#include<unistd.h>
#include<sys/types.h>
#include<sys/mman.h>
#include<stdio.h>
#include<fcntl.h>
#include<assert.h>
#include<time.h>
#define ADC_PAGE 0x80900000 // ADC result (+0x08) ADCSwitch (+0x18) ADCSWLock(+0x20) ADCIntEn(+0x24)
#define ADCRESULT_OFFSET 0x0008
#define SDR_MASK 0x80000000
#define DATA_OFFSET 0x0008
#define DATA_MASK 0xFFFF
#define ADCSWITCH_OFFSET 0x0018
#define ADC_CH0 0x0608
#define ADC_CH1 0x0680
#define ADC_CH2 0x0640
#define ADC_CH3 0x0620
#define ADC_CH4 0x0610
#define ADCSWLOCK_OFFSET 0x0020
#define UNLOCK_VAL 0xAA
#define SYSCON_PAGE 0x80930000 //ADCClkDiv (+0x90) DeviceCfg (+0x80)
#define ADCCLKDIV_OFFSET 0x0090
#define SYSCON_UNLOCK 0x00C0
#define TSEN_MASK 0x80000000
#define DEVICECFG_OFFSET 0x0080
#define ADCPD_MASK 0x02
#define ADCEN_MASK 0x20000
#define TRUE 0x01
#define FALSE 0x00
/* prototypes */
void init_ADC(unsigned long adc_page, unsigned long syscon_page);
int read_channel(unsigned long adc_page, unsigned short channel);
static char is_ADC_busy(unsigned long adc_page);
/* globals */
static unsigned long dr_page, adc_page, syscon_page, pld_page;
int adc_result;
/* READ&WRITEs */
static inline unsigned short READ16(unsigned long addr)
unsigned short ret;
asm volatile (
“ldrh %0, [ %1 ]\n”
: “=r” (ret)
: “r” (addr)
: “memory”
return ret;
static inline void WRITE16(unsigned long addr, unsigned short dat)
asm volatile (
“strh %1, [ %0 ]\n”
: “r” (addr), “r” (dat)
: “memory”
static inline unsigned long READ32(unsigned long addr)
unsigned long ret;
asm volatile (
“ldr %0, [ %1 ]\n”
: “=r” (ret)
: “r” (addr)
: “memory”
return ret;
static inline void WRITE32(unsigned long addr, unsigned long dat)
asm volatile (
“str %1, [ %0 ]\n”
: “memory”
static inline unsigned char READ8(unsigned long addr)
unsigned char ret;
asm volatile (
“ldrb %0, [ %1 ]\n”
: “=r” (ret)
: “r” (addr)
: “memory”
return ret;
static inline void WRITE8(unsigned long addr, unsigned char dat)
asm volatile (
“strb %1, [ %0 ]\n”
: “memory”
unsigned long val;
/* set TSEN bit */
val = READ32(syscon_page + ADCCLKDIV_OFFSET);
//unlock the software lock
WRITE32(syscon_page + SYSCON_UNLOCK, UNLOCK_VAL);
WRITE32(syscon_page + ADCCLKDIV_OFFSET, TSEN_MASK | val);
/* set ADCEN bit */
val = READ32(syscon_page + DEVICECFG_OFFSET);
WRITE32(adc_page + SYSCON_UNLOCK, UNLOCK_VAL); //unlock the soft lock
WRITE32(syscon_page + DEVICECFG_OFFSET, val | ADCEN_MASK);
/* clear ADCPD bit */
WRITE32(syscon_page + DEVICECFG_OFFSET, val & ~ADCPD_MASK);
unsigned long val;
WRITE32(adc_page + ADCSWLOCK_OFFSET, UNLOCK_VAL); //unlock the soft lock
//write ADCSwitch reg to select channel
WRITE32(adc_page + ADCSWITCH_OFFSET, channel);
while(is_ADC_busy(adc_page)); //poll ADCResult
//read result from data regisyyter
val = READ32(adc_page + DATA_OFFSET) ;
val = val & DATA_MASK;
return val;
unsigned long val;
val = READ32(adc_page + ADCRESULT_OFFSET);
if((val & SDR_MASK) == SDR_MASK)
return TRUE;
return FALSE;
int main(void)
int devmem = open(“/dev/mem”, O_RDWR|O_SYNC);
assert(devmem != -1);
adc_page = (unsigned long)mmap(0, getpagesize(), PROT_READ|PROT_WRITE,
MAP_SHARED, devmem, ADC_PAGE);
assert(&adc_page != MAP_FAILED);
syscon_page = (unsigned long)mmap(0, getpagesize(), PROT_READ|PROT_WRITE
, MAP_SHARED, devmem, SYSCON_PAGE);
assert(&syscon_page != MAP_FAILED);
alarm(10); //this program has 10 seconds to complete
init_ADC(adc_page, syscon_page);
adc_result = read_channel(adc_page, ADC_CH0);
printf(“Channel 0: Value %d\n”, adc_result);
close(devmem);
return 0;
