Olimex MOD-MP3 standalone running problem
Hi Olimex,
Problem 1.
I have purchased 2 set of MOD-MP3 module, insert 512MB SD/MMC memory card, insert 1.5V battery and press play/forward/reverse switch.
But unable to play any mp3 file from Memory card?
Is any jumper setting is required for standalone application of MOD-MP3?
Problem 2.
I interface MOD-MP3 with CS-E9302 with to disconnect the RESET and DREQ signals on the MOD-MP3 from the UEXT and connect them to some signals from the bigger extenson header.
But how to run the application from RedBoot?
Any otherway to configure the E9302 to run my application?
I gone through forum list for kernel setup other issue, but unable to figure out.
Can you help me to sort out the problem?
Thank in advance
