I’ve wired up a breadboard to connect my Olimex PIC-WEB to a backlit Hitachi-driven LCD. It works great!
It would be nice to have a small PCB & cables available so the next person won’t have work so hard. It’s only a few resistors and a bunch of wiring connections, could probably be done inside one of those cable-shroud setups.
Are there enough PIC-WEB users to justify a small run? I’m happy to provide my design to anyone who wants to build it or even duplicate my breadboard on their workbench.
I don’t think it’ll work with a PIC-MINI-WEB, since the backlit LCDs want 5V.
Hi startty, nice work on getting the LCD working Would it be possible for you to tell me how to connect it up? I have my PIC-MINI-WEB connected to 12v through a LM7805 (i’m powering it through VIN on the header), so could use that 5v for the backlight?
OLIMEX:
PIC-MAXI-WEB is coming with LCD and relays on board
PIC-MICRO-WEB is coming with PIC18F67J20 in DB25 plastic shell and Power-Over-Internet support
Best regards
Tsvetan
sound interesting, can you give more info about PIC-MICRO-WEB? when will it be available? Will it support async/rs232? I have several applications that this sounds very appropriate for.
I’ve got some extra hardware in my supply cabinet.
Would anyone be interested in buying a fully-built and -tested 20 character x 4-row backlit LCD with bright white text on blue background, complete with PIC-WEB interface?
It would be ready to plug into your PIC-WEB’s 20-pin EXTENSTION port. I’ll send sample code & schematics in email so you can customize it for your application.
You might be able to modify it to work with PIC-MINI-WEB and others, but I haven’t tested it.
Just cover some of my costs (parts, shipping, packaging, supplies, custom PC board, etc): $35, add more to ship outside of USA.
If interested, email me: startty (at) startty (dot) com
Hellow, i am trying connect my Olimex PIC-WEB to a backlit Hitachi-driven LCD (5V) and i am using the MC54/74HC541 as a buffer to generate the 5V from my PIC-WEB board to 5V LCD,i am using the 5.3 microchip stack and have configurated my pins like this in hardwareprofil.h:
// LCD I/O pins
#define LCD_DATA_TRIS (TRISE)
#define LCD_DATA_IO (LATE)
#define LCD_RD_WR_TRIS (TRISBbits.TRISB1)
#define LCD_RD_WR_IO (LATBbits.LATB1)
#define LCD_RS_TRIS (TRISBbits.TRISB2)
#define LCD_RS_IO (LATBbits.LATB2)
#define LCD_E_TRIS (TRISBbits.TRISB3)
#define LCD_E_IO (LATBbits.LATB3)
i am sure about pins and buffer connections and get the 5V outputs as intented but still my LCD not working.
