OOCD AT91SAM7X256 problem
Hi!
I have two boards, as far as I can see schematics are identical in the JTAG part. Using the same configuration on Eclipse I can debug one and the other on I cannot. I’m using self made JTAG-USB key. I think flashing also dosn’t work on one board because I cannot see even simplest program running. I have no reset from JTAG key to board (prototype, will have it later), so I reset it manually before falshing/debugging.
My debug config in Eclipse is:
telnet_port 4444
gdb_port 3333
interface ft2232
ft2232_device_desc "USB <-> JTAG A"
ft2232_layout usbjtag
jtag_speed 1
jtag_nsrst_delay 200
jtag_ntrst_delay 200
reset_config srst_only srst_pulls_trst
jtag_device 4 0x1 0xf 0xe
daemon_startup reset
target arm7tdmi little run_and_halt 0
run_and_halt_time 0 30
and in ‘Initialize commands’ window:
target remote localhost:3333
monitor reset
monitor sleep 500
monitor poll
monitor soft_reset_halt
monitor arm7_9 force_hw_bkpts enable
symbol-file proba.elf
break main
continue
The debug output from the “good” board is:
Debug:   jtag.c:1407 jtag_init(): -
Debug:   ft2232.c:1296 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'usbjtag' layout (0403:6010)
Debug:   ft2232.c:1385 ft2232_init_ftd2xx(): current latency timer: 2
Debug:   ft2232.c:1628 usbjtag_init(): 80 18 1b
Debug:   ft2232.c:253 ft2232_speed(): 86 02 00
Debug:   jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST asserted
Debug:   jtag.c:1197 jtag_reset_callback(): -
Debug:   jtag.c:1291 jtag_examine_chain(): JTAG device found: 0x3f0f0f0f (Manufacturer: 0x787, Part: 0xf0f0, Version: 0x3
Debug:   openocd.c:113 main(): jtag init complete
Debug:   embeddedice.c:220 embeddedice_read_reg_w_check(): 4
Debug:   jtag.c:295 jtag_call_event_callbacks(): jtag event: TRST released
Debug:   arm7_9_common.c:707 arm7_9_assert_reset(): target->state: unknown
Debug:   jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST asserted
Warning: arm7_9_common.c:734 arm7_9_assert_reset(): srst resets test logic, too
Debug:   arm7_9_common.c:773 arm7_9_deassert_reset(): target->state: reset
Debug:   jtag.c:295 jtag_call_event_callbacks(): jtag event: SRST released
Debug:   openocd.c:117 main(): target init complete
Debug:   openocd.c:121 main(): flash init complete
Debug:   openocd.c:125 main(): NAND init complete
Debug:   openocd.c:129 main(): pld init complete
Debug:   gdb_server.c:1451 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug:   embeddedice.c:220 embeddedice_read_reg_w_check(): 1
Debug:   arm7_9_common.c:929 arm7_9_halt(): target->state: running
Debug:   embeddedice.c:384 embeddedice_write_reg(): 9: 0xffffffff
Debug:   embeddedice.c:384 embeddedice_write_reg(): 11: 0xffffffff
Debug:   embeddedice.c:384 embeddedice_write_reg(): 12: 0x00000100
Debug:   embeddedice.c:384 embeddedice_write_reg(): 13: 0x000000f7
Debug:   arm7_9_common.c:671 arm7_9_poll(): DBGACK set, dbg_state->value: 0x19
Debug:   embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000005
Debug:   embeddedice.c:384 embeddedice_write_reg(): 12: 0x00000000
Debug:   arm7_9_common.c:1039 arm7_9_debug_entry(): target entered debug from Thumb state
Debug:   arm7_9_common.c:1043 arm7_9_debug_entry(): r0_thumb: 0x00000000, pc_thumb: 0x00100152
Debug:   arm7_9_common.c:1079 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug:   arm7_9_common.c:1083 arm7_9_debug_entry(): thumb state, applying fixups
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0x0020fbec
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x0167f670
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r4: 0x0000005a
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r5: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r6: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r7: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r8: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r9: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r10: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r11: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r13: 0x0020fbec
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r14: 0x00100125
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x0010014c
Debug:   arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x10014c
Debug:   target.c:469 target_call_event_callbacks(): target event 0
Debug:   arm7_9_common.c:929 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:933 arm7_9_halt(): target was already halted
Debug:   gdb_server.c:126 gdb_get_char(): received '$qSupported#37'
Info:    server.c:67 add_connection(): accepted 'gdb' connection from 0
Debug:   gdb_server.c:239 gdb_get_packet(): character: '
and from the ‘bad’ one:
Debug:   arm7_9_common.c:1043 arm7_9_debug_entry(): r0_thumb: 0x00200f64, pc_thumb: 0x002009fe
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x00200f64
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x0020075d
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0x00000001
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x00200f7c
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r4: 0x00200f8c
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r5: 0x00200f4c
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r6: 0x00000010
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r7: 0x00200f64
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r13: 0x00201fa0
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r14: 0x00200a15
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x002009f8
Debug:   arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x2009f8
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qSupported’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$#00’
Debug: gdb_server.c:126 gdb_get_char(): received ‘++$Hc-1#09’
Debug: gdb_server.c:239 gdb_get_packet(): character: ‘+’
Warning: gdb_server.c:246 gdb_get_packet(): acknowledgment received, but no packet pending
Debug: gdb_server.c:239 gdb_get_packet(): character: ’
and from the 'bad' one:
§DISCOURSE_HOISTED_CODE_3§
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'Hc-1'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$#00'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$qC#b4'
§_DISCOURSE_HOISTED_CODE_3_§
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qC’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$qOffsets#4b’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qOffsets'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$?#3f'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘?’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$S02#b5’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$Hg0#df’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'Hg0'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$pf#d6'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘pf’
Debug: gdb_server.c:663 gdb_get_register_packet(): -
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$4c011000#b9’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+’
Debug: gdb_server.c:126 gdb_get_char(): received ‘$m10014c,4#26’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'm10014c,4'
Debug:   gdb_server.c:817 gdb_read_memory_packet(): addr: 0x0010014c, len: 0x00000004
Debug:   arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x0010014c, size: 0x00000004, count: 0x00000001
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$6a466b46#03'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$qSymbol::#5b'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qSymbol::’
Debug: gdb_server.c:126 gdb_get_char(): received ‘$qRcmd,7265736574#37’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qRcmd,7265736574'
Debug:   target.c:1441 handle_reset_command(): -
Debug:   arm7_9_common.c:707 arm7_9_assert_reset(): target->state: halted
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$OK#9a'
Debug:   gdb_server.c:126 gdb_get_char(): received '+'
Debug:   arm7_9_common.c:671 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug:   arm7_9_common.c:1047 arm7_9_debug_entry(): target entered debug from ARM state
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x000000d3
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0x466b466a
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x00000060
Debug:   arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x60
Debug:   gdb_server.c:126 gdb_get_char(): received '$qRcmd,736c65657020353030#f3'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qRcmd,736c65657020353030’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$OK#9a’
Debug: gdb_server.c:126 gdb_get_char(): received ‘$qRcmd,706f6c6c#58’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qRcmd,706f6c6c'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O7461726765742073746174653a2068616c7465640a#76'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O7461726765742068616c74656420696e2041524d2073746174652064756520746f20646562756720726571756573742c2063757272656e74206d6f64653a2053757065727669736f720a#ae'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O637073723a20307830303030303064332070633a20307830303030303036300a#85'
Debug:   gdb_server.c:126 gdb_get_char(): received '$qRcmd,736f66745f72657365745f68616c74#23'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qRcmd,736f66745f72657365745f68616c74’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$O72657175657374696e67207461726765742068616c7420616e6420657865637574696e67206120736f66742072657365740a#04’
Debug: gdb_server.c:126 gdb_get_char(): received ‘$qRcmd,61726d375f3920666f7263655f68775f626b70747320656e61626c65#2e’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qRcmd,61726d375f3920666f7263655f68775f626b70747320656e61626c65'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O666f72636520686172647761726520627265616b706f696e747320656e61626c65640a#fc'
Debug:   gdb_server.c:126 gdb_get_char(): received '$Z0,100126,2#3e'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘Z0,100126,2’
Debug: gdb_server.c:1078 gdb_breakpoint_watchpoint_packet(): -
Debug: arm7_9_common.c:271 arm7_9_add_breakpoint(): forcing use of hardware breakpoint at address 0x00100126
Debug: breakpoints.c:95 breakpoint_add(): added hardware breakpoint at 0x00100126 of length 0x00000002
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$vCont?#49
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'vCont?'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$Hc0#db'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘Hc0’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$c#63’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'c'
Debug:   gdb_server.c:1025 gdb_step_continue_packet(): -
Debug:   gdb_server.c:1039 gdb_step_continue_packet(): continue
Debug:   arm7_9_common.c:1431 arm7_9_resume(): -
Debug:   embeddedice.c:384 embeddedice_write_reg(): 8: 0x00100126
Debug:   embeddedice.c:384 embeddedice_write_reg(): 9: 0x00000001
Debug:   arm7_9_common.c:1230 arm7_9_restore_context(): -
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining User mode
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r0
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r1
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r2
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r3
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r4
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r5
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r6
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r7
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r8
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r9
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r10
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r11
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r12
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: pc
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: cpsr
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 0 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 1 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 2 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 3 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 4 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 5 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 6 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 7 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 8 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 9 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 10 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 11 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 12 of mode User with value 0xffffffff
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining FIQ mode
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining IRQ mode
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining Supervisor mode
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: r13_svc
Debug:   arm7_9_common.c:1260 arm7_9_restore_context(): examining dirty reg: lr_svc
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 13 of mode Supervisor with value 0xffffffff
Debug:   arm7_9_common.c:1309 arm7_9_restore_context(): writing register 14 of mode Supervisor with value 0xffffffff
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining Abort mode
Debug:   arm7_9_common.c:1246 arm7_9_restore_context(): examining Undefined mode
Debug:   arm7_9_common.c:1342 arm7_9_restore_context(): writing cpsr with value 0x000000d3
Debug:   arm7tdmi.c:478 arm7tdmi_write_xpsr(): xpsr: 000000d3, spsr: 0
Debug:   arm7_9_common.c:1349 arm7_9_restore_context(): writing PC with value 0x00000000
Debug:   embeddedice.c:384 embeddedice_write_reg(): 0: 0x00000000
Debug:   target.c:469 target_call_event_callbacks(): target event 1
Debug:   arm7_9_common.c:1534 arm7_9_resume(): target resumed
Debug:   arm7_9_common.c:1043 arm7_9_debug_entry(): r0_thumb: 0x00000000, pc_thumb: 0x0010012c
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r2: 0x00100fe4
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r3: 0x00000000
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r5: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r6: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r8: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r9: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r10: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r12: 0xffffffff
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r15: 0x00100126
Debug:   arm7_9_common.c:1114 arm7_9_debug_entry(): entered debug state at PC 0x100126
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$T05#b9'
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$26011000#8a’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$z0,100126,2#5e’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'z0,100126,2'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$m100126,4#f7'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘m100126,4’
Debug: gdb_server.c:817 gdb_read_memory_packet(): addr: 0x00100126, len: 0x00000004
Debug: arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x00100126, size: 0x00000001, count: 0x00000004
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$6a460023#c6’
Debug: gdb_server.c:126 gdb_get_char(): received ‘$pd#d4’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'pd'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$ecfb2000#52'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$qfThreadInfo#bb'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘qfThreadInfo’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$qL1160000000000000000#55’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qL1160000000000000000'
Debug: gdb_server.c:126 gdb_get_char(): received ‘$p0#a0’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p0'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$00000000#80'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p1#a1'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p1’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$00000000#80’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p2#a2’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p2'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$e40f1000#f0'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p3#a3'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p3’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p4#a4’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p4'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$5a000000#b6'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p5#a5'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p5’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$ffffffff#30’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p6#a6’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p6'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$ffffffff#30'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p7#a7'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p7’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p8#a8’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p8'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p9#a9'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p9’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$pa#d1’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'pa'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$pb#d2'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘pb’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$pc#d3’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'pc'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$pe#d5'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘pe’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$25011000#89’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p10#d1’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p10'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$000000000000000000000000#80'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p11#d2'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p11’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$000000000000000000000000#80’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p12#d3’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p12'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p13#d4'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p13’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p14#d5’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p14'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p15#d6'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p15’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p16#d7’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p16'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p17#d8'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p17’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$p18#d9’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'p18'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$p19#da'
Debug: gdb_server.c:1338 gdb_input(): recevied packet: ‘p19’
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$f3000060#bf’
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qSupported'
Debug:   gdb_server.c:126 gdb_get_char(): received '++$Hc-1#09'
Debug:   gdb_server.c:239 gdb_get_packet(): character: '+'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qC'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$qOffsets#4b'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: '?'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$S02#b5'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$Hg0#df'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'pf'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$f8092000#c9'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$m2009f8,4#36'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'm2009f8,4'
Debug:   gdb_server.c:817 gdb_read_memory_packet(): addr: 0x002009f8, len: 0x00000004
Debug:   arm7_9_common.c:1779 arm7_9_read_memory(): address: 0x002009f8, size: 0x00000004, count: 0x00000001
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$00f063fa#26'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qSymbol::'
Debug:   gdb_server.c:126 gdb_get_char(): received '$qRcmd,7265736574#37'
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r0: 0x00000093
Debug:   arm7_9_common.c:1108 arm7_9_debug_entry(): r1: 0xfa63f000
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qRcmd,736c65657020353030'
Debug:   gdb_server.c:126 gdb_get_char(): received '$qRcmd,706f6c6c#58'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O637073723a20307830303030303039332070633a20307830303030303036300a#87'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'qRcmd,736f66745f72657365745f68616c74'
Debug:   gdb_server.c:179 gdb_put_packet(): sending packet '$O72657175657374696e67207461726765742068616c7420616e6420657865637574696e67206120736f66742072657365740a#04'
Debug:   gdb_server.c:126 gdb_get_char(): received '$qRcmd,61726d375f3920666f7263655f68775f626b70747320656e61626c65#2e'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'Z0,100126,2'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$vCont?#49'
Debug:   gdb_server.c:1338 gdb_input(): recevied packet: 'Hc0'
Debug:   gdb_server.c:126 gdb_get_char(): received '+$c#63'
I’m sorry - the rest of the post is here (partly overlapping)
In the ‘bad’ debug output it keeps going that way and Eclipse hangs on 36%.
What could be the cause? I can also provide flashing config, scripts and debug output.
Is it possible that I wrote sth in the ‘good’ board’s processor memory earlier on, while trying to get JTAG/OOCD running and later on deleted it from config/script but it still works and I didn’t write it in the ‘bad’ board’s (which is newer board version of my design) processor memory and it doesn’t want to work? I don’t suppose so, but …
I would really appreciate somebody’s help. Thank you in advance!
Vega
In the 'bad' debug output it keeps going that way and Eclipse hangs on 36%.
Is it possible that I wrote sth in the 'good' board's processor memory earlier on, while trying to get JTAG/OOCD running and later on deleted it from config/script but it still works and I didn't write it in the 'bad' board's (which is newer board version of my design) processor memory and it doesn't want to work? I don't suppose so, but ...
I would really appreciate somebody's help. Thank you in advance!
Vega
Vega
Vega
Vega
Vega
Vega
Debug: gdb_server.c:179 gdb_put_packet(): sending packet ‘$f8092000#c9’
Debug: gdb_server.c:126 gdb_get_char(): received ‘+$m2009f8,4#36’
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Vega
Ok, I solved the problem, but I don’t understand why, yet.
I forgot to set the GPNVM2 bit to run the application from flash, so the samba was running all the time. When I set the bit it appeared that the flashing through JTAG went ok and the program worked.
But I don’t understand why I couldn’t get debugger working when the processor booted with samba. When I set the bit and application booted instead of samba - the debugger in eclipse started to work.
Can anybody help me understand it? Thanks.
Vega
