What causes error card init?
How to solve this problem?The suspicion is caused by lithium batteries. Please give guidance on how to solve it.
What size card are you using and how did you format the card?
We recommend cards that are 32gb or smaller in size and formatting the cards with the SD Card Associations formatting utility that you can download at the link below. (Some 64gb cards may work, be lower capacity cards seem to be the most reliable.)
Give the formatter utility a try and let us know if you’re still having trouble.](SD Memory Card Formatter for Windows/Mac | SD Association)
It takes four to five hours of continuous work to be unusual.
Does static electricity affect it?
Because it’s worn on the arm.I hope you can help me. Thank you.
