OPENOCD in a large JTAG chain
Dear All
We need to work on a JTAG chain made from 65 devices; our target is to program the SAM7 processor which is the first device in the chain ; as you can see in the following description, there is a multiple repetition of only 4 device in the chain after the SAM7
  1. SAM7 (uControllore della EAST): IRLen=3
  2. ALTERA EPM2210 : IRLen = 10
  3. ALTERA EP4SGX230 : IRLen =10
  4. LATTICE ISP1014 : IRLen = 8
  5. ATMEL AT90CAN32 : IRLen = 4
  6. ALTERA EPM2210 : IRLen = 10
  7. ALTERA EP4SGX230 : IRLen =10
  8. LATTICE ISP1014 : IRLen = 8
  9. ATMEL AT90CAN32 : IRLen = 4
  10. ALTERA EPM2210 : IRLen = 10
  11. ALTERA EP4SGX230 : IRLen =10
  1. ATMEL AT90CAN32 : IRLen = 4
We already managed to use OPENOCD in a JTAG chain made from only 5 devices using the following JTAG chain description section:
jtag newtap auto0 tap -irlen 4 -ircapture 1 -irmask 0x0f -expected-id 0x0958103f
jtag newtap auto1 tap -irlen 8 -ircapture 1 -irmask 0x03 -expected-id 0x00145043
jtag newtap auto2 tap -irlen 10 -ircapture 1 -irmask 0x3 -expected-id 0x024090dd
jtag newtap auto3 tap -irlen 10 -ircapture 1 -irmask 0x3 -expected-id 0x020a40dd
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 1 -irmask 0x0f -expected-id $_CPUTAPID
but we encounter some problems when we rise to 9 the number of devices in the chain so when we add the next 4 devices and use the following new chain description in the .cfg file
jtag newtap auto4 tap -irlen 4 -ircapture 1 -irmask 0x0f -expected-id 0x0958103f
jtag newtap auto5 tap -irlen 8 -ircapture 1 -irmask 0x03 -expected-id 0x00145043
jtag newtap auto6 tap -irlen 10 -ircapture 1 -irmask 0x3 -expected-id 0x024090dd
jtag newtap auto7 tap -irlen 10 -ircapture 1 -irmask 0x3 -expected-id 0x020a40dd
The error messages I got are:
Open On-Chip Debugger 0.4.0-rc1 (2010-03-25-11:38)
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
1000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: auto0.tap tap/device found: 0x0958103f (mfg: 0x01f, part: 0x9581, ver: 0x0)
Info : JTAG tap: auto1.tap tap/device found: 0x800c5043 (mfg: 0x021, part: 0x00c5, ver: 0x8)
Warn : JTAG tap: auto1.tap UNEXPECTED: 0x800c5043 (mfg: 0x021, part: 0x00c5, ver: 0x8)
Error: JTAG tap: auto1.tap expected 1 of 1: 0x00145043 (mfg: 0x021, part: 0x0145, ver: 0x0)
Info : TAP auto2.tap does not have IDCODE
Warn : JTAG tap: auto2.tap UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
Error: JTAG tap: auto2.tap expected 1 of 1: 0x024090dd (mfg: 0x06e, part: 0x2409, ver: 0x0)
Info : JTAG tap: auto3.tap tap/device found: 0x40902437 (mfg: 0x21b, part: 0x0902, ver: 0x4)
Warn : JTAG tap: auto3.tap UNEXPECTED: 0x40902437 (mfg: 0x21b, part: 0x0902, ver: 0x4)
Error: JTAG tap: auto3.tap expected 1 of 1: 0x020a40dd (mfg: 0x06e, part: 0x20a4, ver: 0x0)
Info : JTAG tap: auto4.tap tap/device found: 0xf020241b (mfg: 0x20d, part: 0x0202, ver: 0xf)
Warn : JTAG tap: auto4.tap UNEXPECTED: 0xf020241b (mfg: 0x20d, part: 0x0202, ver: 0xf)
Error: JTAG tap: auto4.tap expected 1 of 1: 0x0958103f (mfg: 0x01f, part: 0x9581, ver: 0x0)
Info : JTAG tap: auto5.tap tap/device found: 0x38458083 (mfg: 0x041, part: 0x8458, ver: 0x3)
Warn : JTAG tap: auto5.tap UNEXPECTED: 0x38458083 (mfg: 0x041, part: 0x8458, ver: 0x3)
Error: JTAG tap: auto5.tap expected 1 of 1: 0x00145043 (mfg: 0x021, part: 0x0145, ver: 0x0)
Info : JTAG tap: auto6.tap tap/device found: 0x7a003103 (mfg: 0x081, part: 0xa003, ver: 0x7)
Warn : JTAG tap: auto6.tap UNEXPECTED: 0x7a003103 (mfg: 0x081, part: 0xa003, ver: 0x7)
Error: JTAG tap: auto6.tap expected 1 of 1: 0x024090dd (mfg: 0x06e, part: 0x2409, ver: 0x0)
Info : JTAG tap: auto7.tap tap/device found: 0x48160487 (mfg: 0x243, part: 0x8160, ver: 0x4)
Warn : JTAG tap: auto7.tap UNEXPECTED: 0x48160487 (mfg: 0x243, part: 0x8160, ver: 0x4)
Error: JTAG tap: auto7.tap expected 1 of 1: 0x020a40dd (mfg: 0x06e, part: 0x20a4, ver: 0x0)
Info : JTAG tap: at91sam7s256.cpu tap/device found: 0x7c080483 (mfg: 0x241, part: 0xc080, ver: 0x7)
Warn : JTAG tap: at91sam7s256.cpu UNEXPECTED: 0x7c080483 (mfg: 0x241, part: 0xc080, ver: 0x7)
Error: JTAG tap: at91sam7s256.cpu expected 1 of 1: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3)
Warn : Unexpected idcode after end of chain: 257 0xfbf0f878
Warn : Unexpected idcode after end of chain: 289 0xfe000007
Warn : Unexpected idcode after end of chain: 321 0xf0000007
Warn : Unexpected idcode after end of chain: 353 0xc000000f
Warn : Unexpected idcode after end of chain: 385 0x8000007f
Warn : Unexpected idcode after end of chain: 417 0xc000007f
Warn : Unexpected idcode after end of chain: 449 0xe000003f
Warn : Unexpected idcode after end of chain: 481 0xc000003f
Warn : Unexpected idcode after end of chain: 513 0xe000003f
Warn : Unexpected idcode after end of chain: 545 0xf000001f
Warn : Unexpected idcode after end of chain: 577 0xf000000f
Error: double-check your JTAG setup (interface, speed, missing TAPs, …)
Info : JTAG tap: auto1.tap tap/device found: 0xf000001f (mfg: 0x00f, part: 0x0000, ver: 0xf)
Warn : JTAG tap: auto1.tap UNEXPECTED: 0xf000001f (mfg: 0x00f, part: 0x0000, ver: 0xf)
Info : JTAG tap: auto3.tap tap/device found: 0xa0482437 (mfg: 0x21b, part: 0x0482, ver: 0xa)
Warn : JTAG tap: auto3.tap UNEXPECTED: 0xa0482437 (mfg: 0x21b, part: 0x0482, ver: 0xa)
Info : JTAG tap: auto4.tap tap/device found: 0xf810421b (mfg: 0x10d, part: 0x8104, ver: 0xf)
Warn : JTAG tap: auto4.tap UNEXPECTED: 0xf810421b (mfg: 0x10d, part: 0x8104, ver: 0xf)
Info : JTAG tap: auto5.tap tap/device found: 0x212b0003 (mfg: 0x001, part: 0x12b0, ver: 0x2)
Warn : JTAG tap: auto5.tap UNEXPECTED: 0x212b0003 (mfg: 0x001, part: 0x12b0, ver: 0x2)
Info : TAP auto6.tap does not have IDCODE
Warn : JTAG tap: auto6.tap UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
Info : TAP auto7.tap does not have IDCODE
Warn : JTAG tap: auto7.tap UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
Info : JTAG tap: at91sam7s256.cpu tap/device found: 0xe800a281 (mfg: 0x140, part: 0x800a, ver: 0xe)
Warn : JTAG tap: at91sam7s256.cpu UNEXPECTED: 0xe800a281 (mfg: 0x140, part: 0x800a, ver: 0xe)
Warn : Unexpected idcode after end of chain: 195 0x38048243
Warn : Unexpected idcode after end of chain: 227 0x1f020a41
Warn : Unexpected idcode after end of chain: 259 0xfcfc3c3e
Warn : Unexpected idcode after end of chain: 291 0xf800000f
Warn : Unexpected idcode after end of chain: 323 0xe0000007
Warn : Unexpected idcode after end of chain: 355 0xe000001f
Warn : Unexpected idcode after end of chain: 387 0xe000001f
Warn : Unexpected idcode after end of chain: 419 0xf800000f
Warn : Unexpected idcode after end of chain: 451 0xfc000007
Warn : Unexpected idcode after end of chain: 483 0x3fe00000
Warn : Unexpected idcode after end of chain: 515 0xff800000
Warn : Unexpected idcode after end of chain: 547 0xff800000
Warn : Unexpected idcode after end of chain: 579 0xfe000001
Command handler execution failed
Warn : jtag initialization failed; try ‘jtag init’ again.
Could anybody help me ?
Many Thanks in advance for your hints
Paolo
Hi, did you ever find a resolution for this?
We have 10 STM32’s in a chain and having spent the day configuring tools and finally getting things to work I’ve found exactly the same problem…
Open On-Chip Debugger 0.4.0 (2010-11-23-14:20)
Licensed under GNU GPL v2
400 kHz
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain
Info : clock speed 400 kHz
Info : JTAG tap: my_name0.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name0.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name1.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name1.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name2.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name2.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name3.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name3.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name4.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name4.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name5.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name5.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name6.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name6.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name7.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name7.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name8.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name8.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Info : JTAG tap: my_name9.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: my_name9.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
Error: IR capture error at bit 90, saw 0x042211088442211088442211 not 0x…3
Warn : gdb services need one or more targets defined
Amontec Team was able to put 14 Xilinx CPLD in the chain using a Amontec JTAGkey-2.
But failed with Amontec JTAGkey Tiny .
What is the difference ?
The output buffers on JTAGkey-2 are able to driver up to 32ma instead of the 8ma for a Amontec JTAGkey Tiny.
So try with a Amontec JTAGkey-2, almost sure it will work :slight_smile:
Regards,
Laurent
http://www.amontec.com
http://www.amontec.com/jtagkey.shtml
