Hi all
I install precompiled openocd for win32bit from this link
http://www.freddiechopin.info/index.php … 4-openocd#
and add file colled ek-lm3s6965.cfg info boards directory
# Luminary Micro Stellaris LM3S6965 Evaluation Kit
source [find interface/luminary-ek-lm3s6965.cfg]
source [find target/lm3s6965.cfg]
# jtag speed
jtag_khz 500
jtag_nsrst_delay 100
#LM3S9B9x Evaluation Board has only srst
reset_config srst_only
and file luminary-ek-lm3s6965.cfg into interface directory
# Luminary Micro Stellaris LM3S9B9x Evaluation Kits
# In-Circuit Debug Interface (ICDI) Board
# This is a discrete FT2232 based debug board which supports ARM's
# JTAG/SWD connectors in both backwards-compatible 20-pin format and
# in the new-style compact 10-pin. There's also an 8-pin connector
# with serial port support. It's included with LM3S9B9x eval boards.
# http://www.luminarymicro.com/products/ek-lm3s9b90.html
# http://www.luminarymicro.com/products/ek-lm3s9b92.html
interface ft2232
ft2232_device_desc "Stellaris Evaluation Board A"
ft2232_layout luminary_icdi
ft2232_vid_pid 0x0403 0xbcd9
After this i connect board and install drivers from drivers directory. At hardware i seen Stellaris Virtual COM port (Com6).
So i think that all its OK.
But after I will started openocd.exe -f…\board\ek-lm3s6965.cfg
and dont find ftdi device.
Error: unable to open ftdi device: device not found
So I dont have any idea when it was mistake.
Thanks Forrest
