openocd not connecting to target
Hi All
I am trying to connect olimex-ARM-USB-OCD to olimex SAM7-EX256 Rev C dev board in kubuntu 11.10 64 bit OS.
But i am getting the error below, please help
Thank you
Nithin
nithin@nithin-Inspiron-620s:~/project/olimex_sam7_dev_board/All_Interfaces/build$ sudo openocd -f interface/olimex-arm-usb-ocd.cfg -f board/olimex_sam7_ex256.cfg
Open On-Chip Debugger 0.5.0 (2011-08-26-10:36)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
Info : only one transport option; autoselect ‘jtag’
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain
Warn : use ‘sam7x256.cpu’ as target identifier, not ‘0’
Error: flash driver ‘0’ not found
Runtime Error: /usr/share/openocd/scripts/target/sam7x256.cfg:49:
in procedure ‘script’
at file “embedded:startup.tcl”, line 58
at file “/usr/share/openocd/scripts/board/olimex_sam7_ex256.cfg”, line 3
in procedure ‘flash’ called at file “/usr/share/openocd/scripts/target/sam7x256.cfg”, line 49
