I’m at the end of my third week trying to get my Olimex board doing the simple LED flasher. The target board is an Olimex LPC-P2103
I have reinstalled the Olimex for dummies CD.
When I do the Run External to get the OpenOCD running I get
Debug: jtag.c:1210 jtag_init():
Debug: ft2232.c:991 ft2232_init(): ‘ft2232’ interface using FTD2XX with ‘olimex-jtag’ layout
Debug: ft2232.c:1077 ft2232_init(): current latency timer: 2
Debug: ft2232.c:1330 olimex_jtag_init(): 80 08 1b
Debug: ft2232.c:1373 olimex_jtag_init(): 82 09 0f
Debug: ft2232.c:242 ft2232_speed(): 86 01 00
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1096 jtag_reset_callback():
Debug: openocd.c:100 main(): jtag init complete
Debug: arm7_9_common.c:656 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 0
Debug: ft2232.c:738 olimex_jtag_reset(): trst: 1, srst: 1, high_output: 0x02, high_direction: 0x0f
Debug: ft2232.c:738 olimex_jtag_reset(): trst: 0, srst: 1, high_output: 0x03, high_direction: 0x0f
Debug: arm7_9_common.c:722 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 2
Debug: ft2232.c:738 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: openocd.c:104 main(): target init complete
Debug: openocd.c:108 main(): flash init complete
Debug: gdb_server.c:1347 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: arm7_9_common.c:838 arm7_9_halt(): target->state: reset
Debug: embeddedice.c:253 embeddedice_write_reg(): 9: 0xffffffff
Debug: jtag.c:247 jtag_call_event_callbacks(): jtag event: 3
Debug: embeddedice.c:253 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:253 embeddedice_write_reg(): 13: 0x000000f7
Debug: embeddedice.c:157 embeddedice_read_reg_w_check(): 1
Debug: arm7_9_common.c:620 arm7_9_poll(): DBGACK set, dbg_state->value: 0x4f1f0f0f
Debug: embeddedice.c:253 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:253 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:944 arm7_9_debug_entry(): target entered debug from ARM state
Error: armv4_5.c:186 armv4_5_mode_to_number(): invalid mode value encountered
Error: arm7_9_common.c:972 arm7_9_debug_entry(): cpsr contains invalid mode value - communication failure
Error: target.c:1054 handle_target(): couldn’t poll target, exiting
My config file is this:
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc “Olimex OpenOCD JTAG TINY A”
ft2232_layout “olimex-jtag”
ft2232_vid_pid 0x15BA 0x0004
jtag_speed 3
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst separate
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target
#target arm7tdmi
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
run_and_halt_time 0 30
#target_script 0 reset oocd_flash2138.script
working_area 0 0x40000000 0x40000 nobackup
#flash configuration
flash bank lpc2000 0x0 0x40000 0 0 lpc2000_v1 0 14765 calc_checksum
For more information about the configuration files, take a look at:
http://openfacts.berlios.de/index-en.ph … p+Debugger
Any clues?
