I’m trying to use openOCD on NUCLEO-H743ZI https://www.st.com/en/evaluation-tools/ … 743zi.html with the following command:
openocd.exe -f board/st_nucleo_h743zi.cfg
but I get the following error:
GNU MCU Eclipse 64-bit Open On-Chip Debugger 0.10.0+dev-00352-gaa6c7e9b (2018-11-27-08:21)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 1800 kHz
adapter_nsrst_delay: 100
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
D:/_app/GNU MCU Eclipse/OpenOCD/0.10.0-10-20181127-0819/bin/..//scripts/target/stm32h7x.cfg:102: Error: invalid command name "stm32h7x.dap"
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "D:/_app/GNU MCU Eclipse/OpenOCD/0.10.0-10-20181127-0819/bin/..//scripts/board/st_nucleo_h743zi.cfg", line 8
at file "D:/_app/GNU MCU Eclipse/OpenOCD/0.10.0-10-20181127-0819/bin/..//scripts/target/stm32h7x_dual_bank.cfg", line 2
at file "D:/_app/GNU MCU Eclipse/OpenOCD/0.10.0-10-20181127-0819/bin/..//scripts/target/stm32h7x.cfg", line 102
Any hint on how to fix it?
