Hi guys i am setting up environment for imote2 i that i found a problem
how to access password or username in svn checkout -r 516 http://svn.berlios.de/svnroot/repos/openocd/trunk openocd-svn
Or suggest me an alternate method
plz help
plz help
OpenOCD project files were moved to [Sourceforge at the end of 2011. Looks like Git rather than svn.
(The announcements sounded as if berlios.de was shutting down completely. Not sure what is still there…)](http://openocd.sourceforge.net/)
i am trying to use git in tinyos 2.x ubuntu 7.4 on vmware but it gives me error message
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Couldn’t find package git
plz help me in that what i do…
To get that version from sf git repo:
git clone git://openocd.git.sourceforge.net/gitroot/openocd/openocd
git checkout 3b2a068ea997323eb37251b31be8034c57ff9def
However i would suggest you try to use to use the latest version of OpenOCD.
Cheers
Spen
i want to ask when i use git clone git://openocd.git.sourceforge.net/gitroot/openocd/openocd
it ask me to install git …i try to install it
nawaz@nawaz-desktop:~$ sudo apt-get install git
Password:
how i install git on tinyos 2,x on vmware
Not an OpenOCD question really but try:
sudo apt-get install git-core
Spen
i copy openocd 06.0 from sourceforge
but tell me from where i found
arm-usb-tiny.cfg
i found only arm-usb-ocd.cfg
what i do
I would guess that the interface cfg’s have been renamed to olimex-jtag-tiny.cfg
If you want the actual file mentioned then google is your friend:
http://enl.usc.edu/pipermail/t2-imote2/ … 00110.html
Cheers
Spen
when i use while using openocd
./bootstrap
it gives error message libtool is missing
plz tell me what i do
sudo apt-get install libtool
Spen
i try to install openocd on ubuntu 12.04
but get errors
nawazbaig@ubuntu:~/openocd$ sudo make $PARALLEL
make all-recursive
make[1]: Entering directory `/home/nawazbaig/openocd’
Making all in jimtcl
make[2]: Entering directory `/home/nawazbaig/openocd/jimtcl’
make[2]: Nothing to be done for `all’.
make[2]: Leaving directory `/home/nawazbaig/openocd/jimtcl’
Making all in src
make[2]: Entering directory `/home/nawazbaig/openocd/src’
make all-recursive
make[3]: Entering directory `/home/nawazbaig/openocd/src’
Making all in jtag
make[4]: Entering directory `/home/nawazbaig/openocd/src/jtag’
make all-recursive
make[5]: Entering directory `/home/nawazbaig/openocd/src/jtag’
Making all in drivers
make[6]: Entering directory `/home/nawazbaig/openocd/src/jtag/drivers’
make[6]: Nothing to be done for `all’.
make[6]: Leaving directory `/home/nawazbaig/openocd/src/jtag/drivers’
make[6]: Entering directory `/home/nawazbaig/openocd/src/jtag’
make[6]: Nothing to be done for `all-am’.
make[6]: Leaving directory `/home/nawazbaig/openocd/src/jtag’
make[5]: Leaving directory `/home/nawazbaig/openocd/src/jtag’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/jtag’
Making all in helper
make[4]: Entering directory `/home/nawazbaig/openocd/src/helper’
make all-am
make[5]: Entering directory `/home/nawazbaig/openocd/src/helper’
make[5]: Nothing to be done for `all-am’.
make[5]: Leaving directory `/home/nawazbaig/openocd/src/helper’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/helper’
Making all in target
make[4]: Entering directory `/home/nawazbaig/openocd/src/target’
make all-am
make[5]: Entering directory `/home/nawazbaig/openocd/src/target’
make[5]: Leaving directory `/home/nawazbaig/openocd/src/target’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/target’
Making all in transport
make[4]: Entering directory `/home/nawazbaig/openocd/src/transport’
make[4]: Nothing to be done for `all’.
make[4]: Leaving directory `/home/nawazbaig/openocd/src/transport’
Making all in flash
make[4]: Entering directory `/home/nawazbaig/openocd/src/flash’
Making all in nor
make[5]: Entering directory `/home/nawazbaig/openocd/src/flash/nor’
make[5]: Nothing to be done for `all’.
make[5]: Leaving directory `/home/nawazbaig/openocd/src/flash/nor’
Making all in nand
make[5]: Entering directory `/home/nawazbaig/openocd/src/flash/nand’
make[5]: Leaving directory `/home/nawazbaig/openocd/src/flash/nand’
make[5]: Entering directory `/home/nawazbaig/openocd/src/flash’
make[5]: Leaving directory `/home/nawazbaig/openocd/src/flash’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/flash’
Making all in svf
make[4]: Entering directory `/home/nawazbaig/openocd/src/svf’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/svf’
Making all in xsvf
make[4]: Entering directory `/home/nawazbaig/openocd/src/xsvf’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/xsvf’
Making all in pld
make[4]: Entering directory `/home/nawazbaig/openocd/src/pld’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/pld’
Making all in server
make[4]: Entering directory `/home/nawazbaig/openocd/src/server’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/server’
Making all in rtos
make[4]: Entering directory `/home/nawazbaig/openocd/src/rtos’
make[4]: Leaving directory `/home/nawazbaig/openocd/src/rtos’
make[4]: Entering directory `/home/nawazbaig/openocd/src’
make[4]: Nothing to be done for `all-am’.
make[4]: Leaving directory `/home/nawazbaig/openocd/src’
make[3]: Leaving directory `/home/nawazbaig/openocd/src’
make[2]: Leaving directory `/home/nawazbaig/openocd/src’
Making all in doc
make[2]: Entering directory `/home/nawazbaig/openocd/doc’
restore=: && backupdir=“.am$$” && \
am__cwd=pwd && CDPATH=“${ZSH_VERSION+.}:” && cd . && \
rm -rf $backupdir && mkdir $backupdir && \
if (/bin/bash /home/nawazbaig/openocd/missing --run makeinfo --version) >/dev/null 2>&1; then \
for f in openocd.info openocd.info-[0-9] openocd.info-[0-9][0-9] openocd.i[0-9] openocd.i[0-9][0-9]; do \
if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
else :; fi && \
cd “$am__cwd”; \
if /bin/bash /home/nawazbaig/openocd/missing --run makeinfo -I . \
-o openocd.info openocd.texi; \
then \
rc=0; \
CDPATH=“${ZSH_VERSION+.}:” && cd .; \
else \
rc=$?; \
$restore $backupdir/* echo "./openocd.info" | sed 's|[^/]*$||'; \
fi; \
rm -rf $backupdir; exit $rc
openocd.texi:12: @include `version.texi’: No such file or directory.
openocd.texi:37: warning: undefined flag: VERSION.
openocd.texi:38: warning: undefined flag: UPDATED.
openocd.texi:58: warning: undefined flag: VERSION.
openocd.texi:59: warning: undefined flag: UPDATED.
makeinfo: Removing output file `openocd.info’ due to errors; use --force to preserve.
make[2]: *** [openocd.info] Error 1
make[2]: Leaving directory `/home/nawazbaig/openocd/doc’
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/nawazbaig/openocd’
make: *** [all] Error 2
firstly you need to read the OpenOCD docs, in short do the following
run ./bootstrap
run configure
as you are using the developer git version you need to add some extra configure options, eg.
./configure --enable-maintainer-mode --enable-…
make
sudo make install
do not run build under sudo, only the install.
Cheers
Spen
whe i run the following command
./configure --enable-maintainer-mode --enable-ft2232_ftd2xx
i get the following error
checking for library containing FT_GetLibraryVersion… no
configure: error: You appear to be missing the FTD2xx driver library.
I think you need todo a bit more research into building OpenOCD.
That error is caused because as it suggests you do not have the ftdi libs installed.
I would suggest you use libftdi rather than the closed src ftd2xx drivers
sudo apt-get install libftdi-dev
./configure --enable-maintainer-mode --enable-ft2232_libftdi
we are currently testing a newer ftdi driver, but use the above to get started.
Spen
