The str912 is fully erased, then i try to “lock”.
Good news. I found out what was the problem.
OpenOCD stops responding if executed “enable_turbo” in my script.
My new confLOCK.script:
str9xpec lock 0
shutdown
The first debug log is whit my old script and the second with my newone.
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
Debug: 7 15 command.c:432 command_run_line(): script openocd_confLOCK.cfg
Debug: 8 15 configuration.c:87 open_file_from_path(): opened openocd_confLOCK.cfg
Debug: 10 15 command.c:432 command_run_line(): telnet_port 4444
Debug: 12 15 command.c:432 command_run_line(): gdb_port 3333
Debug: 14 15 command.c:432 command_run_line(): gdb_memory_map enable
Debug: 16 15 command.c:432 command_run_line(): gdb_flash_program enable
Debug: 18 15 command.c:432 command_run_line(): interface ft2232
Debug: 20 15 command.c:432 command_run_line(): ft2232_device_desc "Olimex OpenOCD JTAG A"
Debug: 22 15 command.c:432 command_run_line(): ft2232_layout "olimex-jtag"
Debug: 24 15 command.c:432 command_run_line(): ft2232_vid_pid 0x15BA 0x0003
Debug: 26 15 command.c:432 command_run_line(): jtag_speed 1
Debug: 27 15 jtag.c:1863 handle_jtag_speed_command(): handle jtag speed
Info: 28 15 options.c:50 configuration_output_handler(): jtag_speed: 1, 1
Debug: 30 15 command.c:432 command_run_line(): jtag_nsrst_delay 100
Debug: 32 15 command.c:432 command_run_line(): jtag_ntrst_delay 100
Debug: 34 15 command.c:432 command_run_line(): reset_config trst_and_srst
Debug: 36 15 command.c:432 command_run_line(): jtag_device 8 0x1 0x1 0xfe
Debug: 38 15 command.c:432 command_run_line(): jtag_device 4 0x1 0xf 0xe
Debug: 40 15 command.c:432 command_run_line(): jtag_device 5 0x1 0x1 0x1e
Debug: 42 15 command.c:432 command_run_line(): daemon_startup reset
Info: 43 15 options.c:50 configuration_output_handler(): Open On-Chip Debugger (2008-06-19 19:00) svn: 717
Debug: 45 15 command.c:432 command_run_line(): target arm966e little run_and_init 1 arm966e
Debug: 46 15 arm966e.c:142 arm966e_target_command(): chain_pos: 1, variant: arm966e
Debug: 48 15 command.c:432 command_run_line(): run_and_halt_time 0 30
Debug: 50 15 command.c:432 command_run_line(): target_script 0 reset confLOCK.script
Debug: 52 15 command.c:432 command_run_line(): working_area 0 0x50000000 16384 nobackup
Debug: 54 15 command.c:432 command_run_line(): flash bank str9xpec 0x00000000 0x00080000 0 0 0
Debug: 56 15 command.c:432 command_run_line(): init
Debug: 57 31 openocd.c:102 handle_init_command(): target init complete
Debug: 58 31 ft2232.c:1374 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'olimex-jtag' layout (15ba:0003)
Debug: 59 47 ft2232.c:1463 ft2232_init_ftd2xx(): current latency timer: 2
Debug: 60 47 ft2232.c:1810 olimex_jtag_init(): 80 08 1b
Debug: 61 47 ft2232.c:1853 olimex_jtag_init(): 82 09 0f
Debug: 62 47 ft2232.c:253 ft2232_speed(): 86 01 00
Debug: 63 62 openocd.c:109 handle_init_command(): jtag interface init complete
Debug: 64 62 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug: 65 62 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 66 62 jtag.c:1295 jtag_reset_callback(): -
Debug: 67 62 jtag.c:1295 jtag_reset_callback(): -
Debug: 68 62 jtag.c:1295 jtag_reset_callback(): -
Debug: 69 62 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 70 62 jtag.c:1295 jtag_reset_callback(): -
Debug: 71 62 jtag.c:1295 jtag_reset_callback(): -
Debug: 72 62 jtag.c:1295 jtag_reset_callback(): -
Info: 73 78 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x04570041 (Manufacturer: 0x020, Part: 0x4570, Version: 0x0)
Info: 74 78 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x25966041 (Manufacturer: 0x020, Part: 0x5966, Version: 0x2)
Info: 75 78 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x2457f041 (Manufacturer: 0x020, Part: 0x457f, Version: 0x2)
Debug: 76 78 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 77 78 jtag.c:1295 jtag_reset_callback(): -
Debug: 78 78 jtag.c:1295 jtag_reset_callback(): -
Debug: 79 78 jtag.c:1295 jtag_reset_callback(): -
Debug: 80 78 openocd.c:116 handle_init_command(): jtag init complete
Debug: 81 78 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000000
Debug: 82 78 openocd.c:119 handle_init_command(): jtag examine complete
Debug: 83 78 openocd.c:126 handle_init_command(): flash init complete
Debug: 84 78 openocd.c:130 handle_init_command(): NAND init complete
Debug: 85 78 openocd.c:134 handle_init_command(): pld init complete
Debug: 86 93 gdb_server.c:2036 gdb_init(): gdb service for target arm966e at port 3333
Debug: 88 93 command.c:432 command_run_line(): reset
Debug: 89 93 target.c:1851 handle_reset_command(): -
Debug: 90 93 ft2232.c:253 ft2232_speed(): 86 01 00
Debug: 91 93 jtag.c:1581 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / TLR
Debug: 92 93 jtag.c:996 jtag_add_reset(): SRST line released
Debug: 93 93 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug: 94 93 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 95 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 96 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 97 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 98 93 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 99 93 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug: 100 93 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 101 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 102 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 103 93 jtag.c:1295 jtag_reset_callback(): -
Debug: 104 93 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 105 93 jtag.c:996 jtag_add_reset(): SRST line released
Debug: 106 93 ft2232.c:1037 olimex_jtag_reset(): trst: 1, srst: 0, high_output: 0x08, high_direction: 0x0f
Debug: 107 203 ft2232.c:1037 olimex_jtag_reset(): trst: 1, srst: 1, high_output: 0x0a, high_direction: 0x0f
Debug: 108 203 ft2232.c:1037 olimex_jtag_reset(): trst: 0, srst: 1, high_output: 0x0b, high_direction: 0x0f
Debug: 109 312 ft2232.c:1037 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x09, high_direction: 0x0f
Debug: 110 531 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug: 111 531 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 112 531 jtag.c:1295 jtag_reset_callback(): -
Debug: 113 531 jtag.c:1295 jtag_reset_callback(): -
Debug: 114 531 jtag.c:1295 jtag_reset_callback(): -
Info: 115 531 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x04570041 (Manufacturer: 0x020, Part: 0x4570, Version: 0x0)
Info: 116 531 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x25966041 (Manufacturer: 0x020, Part: 0x5966, Version: 0x2)
Info: 117 531 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x2457f041 (Manufacturer: 0x020, Part: 0x457f, Version: 0x2)
Debug: 118 531 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 119 531 jtag.c:1295 jtag_reset_callback(): -
Debug: 120 531 jtag.c:1295 jtag_reset_callback(): -
Debug: 121 531 jtag.c:1295 jtag_reset_callback(): -
Debug: 122 531 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000000
Debug: 123 531 arm7_9_common.c:767 arm7_9_assert_reset(): target->state: unknown
Debug: 124 531 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 125 531 ft2232.c:1037 olimex_jtag_reset(): trst: 0, srst: 1, high_output: 0x03, high_direction: 0x0f
Debug: 126 703 arm7_9_common.c:820 arm7_9_deassert_reset(): target->state: reset
Debug: 127 703 jtag.c:996 jtag_add_reset(): SRST line released
Debug: 128 703 ft2232.c:1037 olimex_jtag_reset(): trst: 0, srst: 0, high_output: 0x01, high_direction: 0x0f
Debug: 129 922 target.c:411 target_process_reset(): Waiting for halted stated as approperiate
Debug: 130 922 arm7_9_common.c:960 arm7_9_halt(): target->state: running
Debug: 131 922 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000002
Debug: 132 922 target.c:425 target_process_reset(): Polling target
Debug: 133 922 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 134 922 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Debug: 135 922 arm7_9_common.c:1074 arm7_9_debug_entry(): target entered debug from ARM state
Debug: 136 922 arm7_9_common.c:1106 arm7_9_debug_entry(): target entered debug state in Undefined mode
Debug: 137 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r0: 0x000000db
Debug: 138 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r1: 0x00000000
Debug: 139 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r2: 0x00000000
Debug: 140 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r3: 0x00000000
Debug: 141 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r4: 0x00000000
Debug: 142 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r5: 0x00000000
Debug: 143 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r6: 0x00000000
Debug: 144 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r7: 0x00000000
Debug: 145 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r8: 0x00000000
Debug: 146 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r9: 0x00000000
Debug: 147 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r10: 0x00000000
Debug: 148 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r11: 0x00000000
Debug: 149 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r12: 0x00000083
Debug: 150 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r13: 0x008a0000
Debug: 151 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r14: 0x00000008
Debug: 152 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r15: 0x00000004
Debug: 153 922 arm7_9_common.c:1143 arm7_9_debug_entry(): entered debug state at PC 0x4
Debug: 154 922 target.c:724 target_call_event_callbacks(): target event 0
Debug: 155 922 configuration.c:87 open_file_from_path(): opened confLOCK.script
Info: 156 922 target.c:237 target_init_handler(): executing reset script 'confLOCK.script'
Debug: 158 922 command.c:432 command_run_line(): jtag_reset 0 1
Debug: 159 922 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 160 922 ft2232.c:1037 olimex_jtag_reset(): trst: 0, srst: 1, high_output: 0x0b, high_direction: 0x0f
Debug: 162 1031 command.c:432 command_run_line(): str9xpec enable_turbo 0
Debug: 164 1031 command.c:432 command_run_line(): str9xpec lock 0
Debug: 165 1031 str9xpec.c:165 str9xpec_isc_status(): status: 0x2e
Debug: 166 1031 str9xpec.c:194 str9xpec_isc_enable(): ISC_MODE Enabled
Debug: 7 0 command.c:432 command_run_line(): script openocd_confLOCK.cfg
Debug: 8 0 configuration.c:87 open_file_from_path(): opened openocd_confLOCK.cfg
Debug: 10 0 command.c:432 command_run_line(): telnet_port 4444
Debug: 12 0 command.c:432 command_run_line(): gdb_port 3333
Debug: 14 0 command.c:432 command_run_line(): gdb_memory_map enable
Debug: 16 0 command.c:432 command_run_line(): gdb_flash_program enable
Debug: 18 0 command.c:432 command_run_line(): interface ft2232
Debug: 20 0 command.c:432 command_run_line(): ft2232_device_desc "Olimex OpenOCD JTAG A"
Debug: 22 0 command.c:432 command_run_line(): ft2232_layout "olimex-jtag"
Debug: 24 0 command.c:432 command_run_line(): ft2232_vid_pid 0x15BA 0x0003
Debug: 26 0 command.c:432 command_run_line(): jtag_speed 1
Debug: 27 0 jtag.c:1863 handle_jtag_speed_command(): handle jtag speed
Info: 28 0 options.c:50 configuration_output_handler(): jtag_speed: 1, 1
Debug: 30 0 command.c:432 command_run_line(): jtag_nsrst_delay 100
Debug: 32 0 command.c:432 command_run_line(): jtag_ntrst_delay 100
Debug: 34 0 command.c:432 command_run_line(): reset_config trst_and_srst
Debug: 36 0 command.c:432 command_run_line(): jtag_device 8 0x1 0x1 0xfe
Debug: 38 0 command.c:432 command_run_line(): jtag_device 4 0x1 0xf 0xe
Debug: 40 0 command.c:432 command_run_line(): jtag_device 5 0x1 0x1 0x1e
Debug: 42 0 command.c:432 command_run_line(): daemon_startup reset
Info: 43 0 options.c:50 configuration_output_handler(): Open On-Chip Debugger (2008-06-19 19:00) svn: 717
Debug: 45 0 command.c:432 command_run_line(): target arm966e little run_and_init 1 arm966e
Debug: 46 0 arm966e.c:142 arm966e_target_command(): chain_pos: 1, variant: arm966e
Debug: 48 0 command.c:432 command_run_line(): run_and_halt_time 0 30
Debug: 50 0 command.c:432 command_run_line(): target_script 0 reset confLOCK.script
Debug: 52 0 command.c:432 command_run_line(): working_area 0 0x50000000 16384 nobackup
Debug: 54 0 command.c:432 command_run_line(): flash bank str9xpec 0x00000000 0x00080000 0 0 0
Debug: 56 0 command.c:432 command_run_line(): init
Debug: 57 0 openocd.c:102 handle_init_command(): target init complete
Debug: 58 0 ft2232.c:1374 ft2232_init_ftd2xx(): 'ft2232' interface using FTD2XX with 'olimex-jtag' layout (15ba:0003)
Debug: 59 31 ft2232.c:1463 ft2232_init_ftd2xx(): current latency timer: 2
Debug: 60 31 ft2232.c:1810 olimex_jtag_init(): 80 08 1b
Debug: 61 31 ft2232.c:1853 olimex_jtag_init(): 82 09 0f
Debug: 62 31 ft2232.c:253 ft2232_speed(): 86 01 00
Debug: 63 47 openocd.c:109 handle_init_command(): jtag interface init complete
Debug: 64 47 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug: 65 47 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 66 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 67 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 68 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 69 47 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 70 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 71 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 72 47 jtag.c:1295 jtag_reset_callback(): -
Info: 73 47 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x04570041 (Manufacturer: 0x020, Part: 0x4570, Version: 0x0)
Info: 74 47 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x25966041 (Manufacturer: 0x020, Part: 0x5966, Version: 0x2)
Info: 75 47 jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x2457f041 (Manufacturer: 0x020, Part: 0x457f, Version: 0x2)
Debug: 76 47 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 77 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 78 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 79 47 jtag.c:1295 jtag_reset_callback(): -
Debug: 80 47 openocd.c:116 handle_init_command(): jtag init complete
Debug: 81 62 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000000
Debug: 82 62 openocd.c:119 handle_init_command(): jtag examine complete
Debug: 86 94 gdb_server.c:2036 gdb_init(): gdb service for target arm966e at port 3333
Debug: 88 94 command.c:432 command_run_line(): reset
Debug: 89 94 target.c:1851 handle_reset_command(): -
Debug: 90 94 ft2232.c:253 ft2232_speed(): 86 01 00
Debug: 91 94 jtag.c:1581 jtag_init_reset(): Trying to bring the JTAG controller to life by asserting TRST / TLR
Debug: 92 94 jtag.c:996 jtag_add_reset(): SRST line released
Debug: 93 94 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug: 94 94 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 95 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 96 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 97 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 98 94 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 99 94 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug: 100 94 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG controller reset (TLR or TRST)
Debug: 101 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 102 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 103 94 jtag.c:1295 jtag_reset_callback(): -
Debug: 104 94 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug: 105 94 jtag.c:996 jtag_add_reset(): SRST line released
Debug: 106 94 ft2232.c:1037 olimex_jtag_reset(): trst: 1, srst: 0, high_output: 0x08, high_direction: 0x0f
Debug: 137 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r0: 0xd296d769
Debug: 138 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r1: 0x35fe8210
Debug: 139 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r2: 0x954844b2
Debug: 140 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r3: 0xf8600f58
Debug: 141 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r4: 0x8c61087c
Debug: 142 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r5: 0x42f52888
Debug: 143 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r6: 0x51ed539a
Debug: 144 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r7: 0x22f0748a
Debug: 145 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r8: 0x17fb1e85
Debug: 146 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r9: 0x42a99f75
Debug: 147 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r10: 0x17a69c2d
Debug: 148 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r11: 0xa87bcc9f
Debug: 149 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r12: 0x1a650883
Debug: 150 922 arm7_9_common.c:1137 arm7_9_debug_entry(): r13: 0xec8a4372
Debug: 158 922 command.c:432 command_run_line(): str9xpec lock 0
Debug: 159 922 str9xpec.c:165 str9xpec_isc_status(): status: 0x2e
Debug: 160 922 str9xpec.c:194 str9xpec_isc_enable(): ISC_MODE Enabled
Debug: 161 937 str9xpec.c:165 str9xpec_isc_status(): status: 0x26
Debug: 162 937 str9xpec.c:223 str9xpec_isc_disable(): ISC_MODE Disabled
Debug: 163 937 command.c:387 find_and_run_command(): Command failed with error code -902
Debug: 165 937 command.c:432 command_run_line(): shutdown
Debug: 166 937 ft2232.c:253 ft2232_speed(): 86 01 00
