Has anyone had any luck with using OpenOCD with the Beagleboard and the Flyswatter (tincantools.com).
I’ve tried this with version openocd svn revision 2291
I am able to start the openocd deamon:
./src/openocd -s /Users/fred/Documents/openocd/trunk/tcl -f interface/flyswatter.cfg -f board/ti_beagleboard.cfg
But when I telnet to 4444 and issue the omap3_dbginit command, I get lots of errors. I’ve tried various combinations of connecting power, but always get the same results:
telnet localhost 4444
Trying ::1…
telnet: connect to address ::1: Connection refused
Trying fe80::1…
telnet: connect to address fe80::1: Connection refused
Trying 127.0.0.1…
Connected to localhost.
Escape character is ‘^]’.
Open On-Chip Debugger
omap3_dbginit
JTAG tap: omap3530.jrc tap/device found: 0x0b7ae02f (mfg: 0x017, part: 0xb7ae, ver: 0x0)
JTAG Tap/device matched
AHBAP Cached values: dp_select 0x0, ap_csw 0xa2000012, ap_tar 0xffffffff
SWJ-DP STICKY ERROR
Read MEM_AP_CSW 0x2800052, MEM_AP_TAR 0xe000ed00
SWJ-DP STICKY ERROR
Block read error address 0xe000ed00, count 0x1
AHBAP Cached values: dp_select 0x10, ap_csw 0xa2000002, ap_tar 0xe000edf0
SWJ-DP STICKY ERROR
Read MEM_AP_CSW 0x2800042, MEM_AP_TAR 0xe000edf0
TargetName Type Endian TapName State
0* omap3.cpu cortex_m3 little omap3530.dap unknown
0x54011314 0000000b …
0x54011314 00000001 …
SWJ-DP STICKY ERROR
The AHBAP error repeats forever.
