Good day,
I’m trying to debug an application that I wrote for the ST STM32F103ZET6 (Cortex-M3, 512k flash).
I’ve used OpenOCD/Eclipse/GCC successfully in the past to develop for the STR912 (ARM9).
I have the following setup:
OS: Linux (Ubuntu Karmic)
GCC: 4.2.1 arm-none-eabi (CodeSourcery 2009q3 : 6.8.50.20090630-cvs)
Eclipse: 20100218-1602
OpenOCD: 0.4 (
Dongle: Amontec USB-tiny
I have run into the following OpenOCD error when trying to open a debug session to my target board from within Eclipse:
“rejected ‘gdb’ connection, no more connections allowed”
I’ve tried to issue the gdb commands directly from within a command line gdb session, and OpenOCD accepts all the commands without a problem.
The gdbCommands file that I’ve specified in Eclipse contains the following commands:
target remote localhost:3333
monitor halt
monitor sleep 500
monitor gdb_breakpoint_override hard
monitor wait_halt
monitor sleep 500
symbol-file main.out
set $pc = 0x0
break main
continue
My OpenOCD config file contains the following lines:
source [find interface/jtagkey-tiny.cfg]
source [find target/stm32.cfg]
The output from OpenOCD (-d 3) when I try to open a debug session from withing Eclipse are listed below.
Info : 343 297284 server.c:81 add_connection(): accepting ‘gdb’ connection from 0
Debug: 344 297284 breakpoints.c:161 breakpoint_clear_target(): Delete all breakpoints for target: stm32.cpu
Debug: 345 297284 breakpoints.c:299 watchpoint_clear_target(): Delete all watchpoints for target: stm32.cpu
Debug: 346 297284 target.c:968 target_call_event_callbacks(): target event 25 (gdb-attach)
Debug: 347 297284 gdb_server.c:856 gdb_new_connection(): New GDB Connection: 1, Target stm32.cpu, state: halted
Debug: 348 297284 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSupported’
Debug: 349 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘QStartNoAckMode’
Warn : 350 297285 gdb_server.c:649 gdb_get_packet_inner(): acknowledgment received, but no packet pending
Debug: 351 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘?’
Debug: 352 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc-1’
Debug: 353 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qC’
Debug: 354 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qOffsets’
Debug: 355 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hg0’
Debug: 356 297285 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 357 297286 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qXfer:memory-map:read::0,fff’
Debug: 358 297287 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001872,4’
Debug: 359 297287 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001872, len: 0x00000004
Debug: 360 297287 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08001872
Debug: 361 297362 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qSymbol::’
Debug: 362 297363 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,68616c74’
Debug: 363 297382 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_halt
Debug: 364 297382 command.c:133 script_debug(): command - halt ocd_halt
Debug: 366 297402 target.c:2062 handle_halt_command(): -
Debug: 367 297402 cortex_m3.c:499 cortex_m3_halt(): target->state: halted
Debug: 368 297402 cortex_m3.c:503 cortex_m3_halt(): target was already halted
Debug: 369 297443 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,736c65657020353030’
Debug: 370 297459 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_sleep 500
Debug: 371 297459 command.c:133 script_debug(): command - sleep ocd_sleep 500
Debug: 374 297992 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,6764625f627265616b706f696e745f6f766572726964652068617264’
Debug: 375 298001 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_gdb_breakpoint_override hard
Debug: 376 298001 command.c:133 script_debug(): command - gdb_breakpoint_override ocd_gdb_breakpoint_override hard
User : 378 298004 gdb_server.c:2501 handle_gdb_breakpoint_override_command(): force hard breakpoints
Debug: 379 298007 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,776169745f68616c74’
Debug: 380 298009 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_wait_halt
Debug: 381 298009 command.c:133 script_debug(): command - wait_halt ocd_wait_halt
Debug: 383 298015 gdb_server.c:2147 gdb_input_inner(): received packet: ‘qRcmd,736c65657020353030’
Debug: 384 298017 command.c:133 script_debug(): command - ocd_command ocd_command type ocd_sleep 500
Debug: 385 298017 command.c:133 script_debug(): command - sleep ocd_sleep 500
Debug: 388 298523 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Pf=00000000’
Debug: 389 298523 gdb_server.c:1156 gdb_set_register_packet(): -
Debug: 390 298523 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 391 298523 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m0,4’
Debug: 392 298523 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x00000000, len: 0x00000004
Debug: 393 298523 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x00000000
Debug: 394 298526 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8000202,4’
Debug: 395 298526 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08000202, len: 0x00000004
Debug: 396 298526 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08000202
Debug: 397 298533 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Z1,8001872,2’
Debug: 398 298533 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 399 298533 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x88001871
Debug: 400 298535 cortex_m3.c:963 cortex_m3_set_breakpoint(): fpc_num 0 fpcr_value 0x88001871
Debug: 401 298535 cortex_m3.c:999 cortex_m3_set_breakpoint(): BPID: 1, Type: 0, Address: 0x08001872 Length: 2 (set=1)
Debug: 402 298535 breakpoints.c:102 breakpoint_add(): added hardware breakpoint at 0x08001872 of length 0x00000002, (BPID: 1)
Debug: 403 298535 gdb_server.c:2147 gdb_input_inner(): received packet: ‘vCont?’
Debug: 404 298535 gdb_server.c:2147 gdb_input_inner(): received packet: ‘Hc0’
Debug: 405 298535 gdb_server.c:2147 gdb_input_inner(): received packet: ‘c’
Debug: 406 298535 target.c:968 target_call_event_callbacks(): target event 7 (gdb-start)
Debug: 407 298535 gdb_server.c:1413 gdb_step_continue_packet(): -
Debug: 408 298535 gdb_server.c:1427 gdb_step_continue_packet(): continue
Debug: 409 298537 target.c:1516 target_read_u16(): address: 0x00000000, value: 0x0400
Debug: 410 298537 armv7m.c:129 armv7m_restore_context():
Debug: 411 298541 cortex_m3.c:1424 cortex_m3_store_core_reg_u32(): write core reg 15 value 0x1
Debug: 412 298541 armv7m.c:242 armv7m_write_core_reg(): write core reg 15 value 0x1
Debug: 413 298543 target.c:968 target_call_event_callbacks(): target event 4 (resumed)
Debug: 414 298543 cortex_m3.c:697 cortex_m3_resume(): target resumed at 0x1
Debug: 415 298664 cortex_m3.c:336 cortex_m3_debug_entry():
Debug: 416 298672 cortex_m3.c:151 cortex_m3_clear_halt(): NVIC_DFSR 0x3
Debug: 417 298678 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 0 value 0x20010000
Debug: 418 298682 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 1 value 0x2000fff0
Debug: 419 298686 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 2 value 0x2000026c
Debug: 420 298690 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 3 value 0x2000026c
Debug: 421 298694 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 4 value 0x9d
Debug: 422 298698 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 5 value 0xea3fdbc0
Debug: 423 298702 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 6 value 0xe51fecaa
Debug: 424 298706 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 7 value 0x2000fff0
Debug: 425 298743 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 8 value 0xfbffff7f
Debug: 426 298768 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 9 value 0xffeffffd
Debug: 427 298816 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 10 value 0x374fba7e
Debug: 428 298864 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 11 value 0x95654a70
Debug: 429 298925 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 12 value 0xfbfff7ff
Debug: 430 298968 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 13 value 0x2000fff0
Debug: 431 299020 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 14 value 0x8000203
Debug: 432 299051 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 15 value 0x8001872
Debug: 433 299114 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 16 value 0x61000000
Debug: 434 299174 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 17 value 0x2000fff0
Debug: 435 299192 cortex_m3.c:1346 cortex_m3_load_core_reg_u32(): load from core reg 18 value 0x8b28355c
Debug: 436 299235 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 19 value 0x0
Debug: 437 299282 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 20 value 0x0
Debug: 438 299323 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 21 value 0x0
Debug: 439 299362 cortex_m3.c:1378 cortex_m3_load_core_reg_u32(): load from special reg 22 value 0x0
Debug: 440 299362 cortex_m3.c:396 cortex_m3_debug_entry(): entered debug state in core mode: Thread at PC 0x8001872, target->state: halted
Debug: 441 299362 target.c:968 target_call_event_callbacks(): target event 2 (gdb-halt)
Debug: 442 299362 target.c:968 target_call_event_callbacks(): target event 3 (halted)
Debug: 443 299362 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 444 299362 gdb_server.c:2147 gdb_input_inner(): received packet: ‘g’
Debug: 445 299373 gdb_server.c:2147 gdb_input_inner(): received packet: ‘z1,8001872,2’
Debug: 446 299373 gdb_server.c:1451 gdb_breakpoint_watchpoint_packet(): -
Debug: 447 299373 cortex_m3.c:1022 cortex_m3_unset_breakpoint(): BPID: 1, Type: 0, Address: 0x08001872 Length: 2 (set=1)
Debug: 448 299373 target.c:1565 target_write_u32(): address: 0xe0002008, value: 0x00000000
Debug: 449 299383 breakpoints.c:127 breakpoint_free(): free BPID: 1 → 0
Debug: 450 299383 gdb_server.c:2147 gdb_input_inner(): received packet: ‘m8001872,4’
Debug: 451 299383 gdb_server.c:1251 gdb_read_memory_packet(): addr: 0x08001872, len: 0x00000004
Debug: 452 299383 target.c:1333 target_read_buffer(): reading buffer of 4 byte at 0x08001872
Info : 453 299411 server.c:433 server_loop(): rejected ‘gdb’ connection, no more connections allowed
Debug: 454 299411 gdb_server.c:2147 gdb_input_inner(): received packet: ‘k’
Debug: 455 299411 gdb_server.c:875 gdb_connection_closed(): GDB Close, Target: stm32.cpu, state: halted, gdb_actual_connections=0
Debug: 456 299411 target.c:968 target_call_event_callbacks(): target event 8 (gdb-end)
Debug: 457 299411 target.c:968 target_call_event_callbacks(): target event 26 (gdb-detach)
Info : 458 299411 server.c:455 server_loop(): dropped ‘gdb’ connection - error -400
