Toeknee - Thanks. The TADJ option looks useful. I will have to give it a try.
I have used the Canadian (CSRS) to get a solution. Like you I would like to use OPUS. Using Emlid Studio I have had much better luck. When I do get a solution using the RTKConv file there is less error in the solution from Emlid Studio generated file than the RTKConv generated file.
Thanks for all your suggestions, Eaton99.
Eaton 99:
Interesting. So perhaps Emlid either (a) improved the RTKLIB code or (b) figured out the optimum configuration parameters for RTKCONV.
I would have a slight preference to use RTKCONV if everything else was equal, mostly so I could script the conversion process. But I’ve settled on Emlid Studio for now.
toeknee, It might be a bit of both, improved code and optimum configuration. It is interesting to note that while looking at the link for the TADJ option I noticed that under the MULTICODE option there is mention of the “Emlid version of RTKLIB code”. So, it looks like the author of RTKCONV is aware of the Emlid code.
I would also like to use RTKCONV. When I load the ubx file into RTKPLOT, I can see the data plotted. It shows why you would not want to use the first 5 minutes or so of data. I do not know how to get the Emlid software to do this. After the Emlid software converts the ubx file to RINEX it shows a graph, but I am not sure how to interpret that to know whether my data is any good or not.
