Pad 49 on the ATP board?
I’m using Teensy MicroMod and I’m trying to access pad 49/pin 22 (A8) on the ATP board. Is this Pad/Pin not broken out on the ATP?
On an Micromod ATP board the pin49 is used as VIN3. It is an INPUT from a voltage divider to the processor. It is not broken out.
I do see that - but I mistakenly thought the ALP board exposed all the pins.
ha ha :slight_smile:
Understand your point. The VIN/3 was intended to check that the provided 3v3 is of the right level.
(https://cdn.sparkfun.com/assets/learn_tutorials/1/2/0/6/SparkFun_MicroMod_Interface_v1.0_-_Pin_Descriptions.pdf)
