I’m confused about the correct layout for the thermocouple connections to a MAX6675 and was hoping someone could clarify for me.
The datasheet shows that you need to ground T- as close to the GND pin as possible. It also says to use a ground plane. However, should you keep the T- trace separate and just link it to GND close to the IC or can the T- pad just be connected directly to the ground plane?
I didn’t think about it initially and when I made the ground plane I got the following which just looks wrong.
So this brings up a question that I probably should have asked a while back but…are there any good resources out there for PCB design? It’s a subject that I’ve always found harder than others to find detailed examples/information on the web.
Are there any good texts available or is it a better idea to just post PCB’s and ask for critique? I’m sure I’m loads more mistakes that would be easy to fix.
