Does anyone have suggestions for circuit board manufacturers? I am looking for inexpensive, short production runs.
I am currently using Gold Phoenix, the same company that BatchPCB uses. I am happy with their prices, turnaround time, and customer service. However, they seem to charge a lot for some options which seem unreasonable too me (more cuts, colored solder mask, minimum size).
I would like to find out what other companies are out there for short runs, international and domestic, that people have experience with.
I’ve used Olimex a bunch of times, and they are OK, and cheap if you just want a small number of boards:
PROS:
Cheap for small PCB size (30 Euro for 25 square inches)
You can panelise as many boards as you want for no extra charge.
Gold plating standard (no extra cost).
Faster than BatchPCB
CONS:
Hole sizes are specified as BEFORE plating, which is the opposite of most places that specify FINISHED hole diameter.
Accuracy (hole alignment & overlay in particular), although usable, is not as good as other places.
They separate the boards by hand with guilotine, so rectangular PCBs ony, and the edges are a bit rough compared with CNC milled PCBs. Not a big problem though.
They want you to fax credit card info on the order form they send you (yes, fax!). I’ve just scanned & emailed with no problems though.
