PCB paper
What paper is better to print on with an ink printer?
You can’t use paper for PCB transparencies. I get very good results with Mega Electronics Premium Jetstar film in my HP 5940 printer. The cheaper standard Jetstar film is OK in many other inkjets.
d4n1s,
Could you elaborate on your question a bit? Do you mean using an ink-jet printer to print transparencies, or are you referring to the method of using a laser printer with regular paper, and ironing it onto a PCB?
