As a noob I apologize for a rather basic question but I am wondering how to connect to the Arduino pins w/o using Dupont connectors which are great for breadboarding and proof of concept but too loose for a final project. I am fine with soldering or some sort of quick disconnect connector.
Nothing wrong with the standard Arduino jumpers as long as the pin & socket is tight. I use them all the time since they are faster than making up custom wire harnesses. The key is to keep the pin & socket joint from being able to work loose. So bundle them together and zip tie the as you you would any harness and secure the harness to a fixed object.
I’ve built a bunch of projects like this, but unfortunately, I didn’t take any photos.
If you need an even better connection than this, then solder on male headers with retention clips and make/buy matching female sockets with wiring to suit.
For one-off projects, I generally use a proto-shield of some type, like https://www.sparkfun.com/products/13820. The tension from all of the pins together is pretty secure. Then just solder whatever connection you need directly to the board.
