I have a pi-topCEED.
I want to program another Raspberry using the pi-top, if possible.
My questions:
How do I redirect the program that I am writing to the second Raspberry? I am going to assume I will use a USB port on the pi-top to the second Raspberry.
I am using NOOBS OS in the pi-top.
I am using the OS that came with the pi-top with the other Raspberry.
I am using Python as a programming language on the pi-top.
Again, can you provide me with the command (s) that I would use in Python to re-direct the program that I am writing to the second Raspberry?
Would there be a better language to use for programing?
Hi RadioOperator,
This question is a bit beyond the scope of SparkFun’s Technical Support so we cannot help you with a direct answer for specific parts/commands to use but I found a few links that might help you get started. Essentially, you just need to create a serial connection between the two Pis. Simply put, you’ll just need to link RX and TX on both Pis as well as the grounds for both Pis.
A quick search of “serial communication between two raspberry pis” turned up a couple of resources that might help you get started here. Here are those links:
[elinux.org
[Raspberry Pi Forum Post
[Quick serial communication tutorial
I hope this information helps you get started with this project!](Setting Up UART Serial Communication between Raspberry Pis)](https://www.raspberrypi.org/forums/viewtopic.php?t=105995)](RPi Serial Connection - eLinux.org)
