Piezoresistive Fabric
I’m looking for a pressure sensitive fabric material like the one that Eeonyx (if you know the company) used to produce. I’ve looked around and found many different options for other touch sensitive materials, but I do need one that is flexible and able to withstand a decent amount of heat. In terms of resistivity, a range of 100K- .5K Ohms, 100K being without any force applied and .5K after the application of about 100 newtons. There was an eeonyx product on Sparkfun, but it has been retired. If anyone has any suggestions of similar products, or how to still acquire the Eeonyx one, that would be great.
Hi SHARAM40.
We only carry one resistive fabric product in our catalog.
[COM-14110
If you’d like more information as to the operating specifics or startup guides, please use the links we’ve provided on our product pages:
[Technical Datasheet
[Startup Guide
I hope this helps point you in the right direction!](HOW TO GET WHAT YOU WANT)](https://cdn.sparkfun.com/datasheets/E-Textiles/Materials/NW170-PI-20%20TDS.pdf)](https://www.sparkfun.com/products/14110)
