I posted 2 weeks ago about how to program a specific address on the smirf v2.0 but nobody reply.Please I need to know how to program and what is the secuence. Is possible Nathan that you give the C code to change things like address, channel, etc?
Another problem is the transmission time. what is the maximium time to send 1 byte usign the smirf?? I’m developping a datalogger using this transceivers but I have to put delays of 5 ms to not loose the link.
Regarding the first part of your question, I’ve been able to run the commands through Hyperterminal just fine, straight out of the datasheet. I suspect that the problem lies in the timing of your code. Or maybe double check the connections…
If I understand your other question correctly, there’s no way to know for sure what the max transit time as it may be necessary to transmit any given packet a number of times depending on traffic on the channel. It might be best to develop your code to accomodate this so as to make sure you don’t lose data.
