Hello! ![]()
I’m completely new to Arduino and have never used it before. Although I’ve heard about it and I known what it is and some basics of what it can do. Anyways, I want to create this portable EL Wire set up that will be attached to this all black costume. I was wondering if it’s not too much, if anybody can just quickly review the parts I will be getting and tell me if they will work according to what I’m trying to do.
What I want this set up of 6-8 EL Wires to do is just control (By manually programming it) when each connected EL Wire turns on and off. I want it so I have multiple EL Wires on at the same time. I want to control these lights for up to 3 minutes and at certain points, each EL wire might be turning on and off several times per second.
I’ve found the parts that I absolutely need such as:
I also need a 12V input (these instructions I read claimed that I needed a wall adapter). Is there any battery that will let me do this? I heard this one works, is it true? https://www.sparkfun.com/products/10470 (Also how would I charge it?)
Now I also know that I need an Arduino board, will I be able to pull this off with an Arduino Pro or Uno? Or will I run out of memory?
If there’s anything that you don’t understand or that’s not clear, please tell me!
I’d appreciate it a lot if anybody can help me out, also if they can tell me if I have everything to fully make this work or if there’s a better way of doing this?
I willing to make 4 sets of this set up which will end up costing around $400-$500 so I need everything to be working smoothly and efficiently with no errors, (if that’s possible with this?)
Thank you very much! ![]()
