stilldavid:
purplegecko:
HiUnfortunately, my workplace still forces be to use IE6, and in there the middle column in the new site drops below the others - it didn’t do this before.
If it’s too much work to fix, I can deal!
pG
Hey, I’m so sorry your workplace forces IE6 on you… there are better browsers!
You should get a splash page when you load the site that informs you that with this release we are no longer supporting IE6. Google, Facebook and many others have dropped support for it and it just takes too many resources to hack into submission. We support IE7+, and most other modern browsers as well as [Google Chrome Frame which is a good option if you are forced to use IE6.
Good luck![/quote]
Oh I know - I use Firefox and Chrome at home!
I’m not getting a splash at work, but that may be because I was already logged in. I will delete my cookies and test tomorrow.
Don’t worry too much - my day job is a web developer, so I understand the pain of IE6!
pG](Chrome Frame)
On the Customer Service page: http://www.sparkfun.com/static/customer_service, the “Technical Assistance” link at the top is broken.
Erik:
follower:
- Attempting to add 100000000000000 of an item only adds 2147483647 items. :)[/list]
[/quote]
The reason we don’t check for overload is - if people want to order that many of any one item, LET THEM! :)[/quote]I suppose we could up the column to a bigint and allow for up to 9,223,372,036,854,775,807 of a single item on an order. Even if that was one of our cheapest little LEDs we could all retire to solid gold moon fortresses following that order.
Frencil:
Erik:
follower:
[/quote]
The reason we don’t check for overload is - if people want to order that many of any one item, LET THEM! :)[/quote]I suppose we could up the column to a bigint and allow for up to 9,223,372,036,854,775,807 of a single item on an order. Even if that was one of our cheapest little LEDs we could all retire to solid gold moon fortresses following that order.[/quote]
I’m more of a platinum guy, but I like the way you think.
As a side note, IT would love to have their own kegerator and a soft serve ice cream machine, so if somebody feels like donating the lowly sum of a couple of thousand dollars straight to us rather than ordering billions of LED’s, this is acceptable as well.
Upload User Image:
I can’t upload a jpeg image. Not sure if this is a new problem or not. The image has a .jpg extension, not .jpeg if that makes a difference.
Logging Out:
Sometimes I’m redirected to http://www.sparkfun.com/index/index
Not too sure if you care, but here are a list of
In page broken links:
Customer Service Page:
Terms of Service and Privacy Policy links
About Page
Press & Media Relations Links.
Contact Page
techincal assistances takes you to: http://www.sparkfun.com/static/technical_assistance.php
Tutorials
http://www.sparkfun.com/tutorials/90
Too lazy to find the rest of the broken ones out of almost 200 tuts.
Bored, so here are some more broken tuts:
How to Read a Datasheet: http://www.sparkfun.com/tutorials/223
Tweeting Kegerator: http://www.sparkfun.com/tutorials/144
Ethernet to Color LED Matrix: http://www.sparkfun.com/tutorials/44
AT91SAM7 Serial Communications: http://www.sparkfun.com/tutorials/90
Your Atmel Board May Not Be Dead: http://www.sparkfun.com/tutorials/63
Nokia 6100: http://www.sparkfun.com/tutorials/64
ARM tutorial: http://www.sparkfun.com/tutorials/66
Re: 404ing tutorials, we’ve got the bug tracked down, should have a fix up shortly.
Edit: Fixed. Deploying in a minute or two.
fixed!matkey:
On the About page (http://www.sparkfun.com/static/about) the Team list points to http://www.sparkfun.com/commerce/team.php
RSS Feed via Google Reader has sent me the last 5 items 3 times now today, with the most recent being in the last hour. Not simply unread items, whole new copies of those items as being unread as if they were brand new items.
When looking at an order in the order history page, items that have >1 quantity do not have correct subtotal.
http://lh6.ggpht.com/_boLXfftmB60/TOLdG … 0issue.png
The subtotal should say something like: $10 ($2 each)
Secure Checkout
I’ve received this message when i wanted to submit my order:
Please fix the errors below in the fields marked with asterisks (*).
This transaction has been declined.
But, there wasn’t any marked fields. Nothing that could inform me where I’ve made a mistake.
I have checked everything and submitted it again just to gain other error:
Found similar transaction.
(or something near those lines).
billbaitsg:
When looking at an order in the order history page, items that have >1 quantity do not have correct subtotal.http://lh6.ggpht.com/_boLXfftmB60/TOLdG … 0issue.png
Fixed, and in the pipeline. Thanks!
LazyBones:
Secure CheckoutI’ve received this message when i wanted to submit my order:
That essentially means that your credit card was declined for one reason or other (likely a typo in the CCV or the actual CC#). Then when you enter it again, there’s now a delay there before another credit card transaction can be approved. If you try again in a few minutes it should work.
We’ll see if we can find another solution to the problem than what we currently do.
Tutorials should now work 100%: no 404s, all images load, etc.
Please let me know if I missed anything!
Can’t add anything to the wish list.
saw errors on this page in the corner.
Running windows 7 and IE8.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Tue, 16 Nov 2010 20:41:45 UTC
Message: ‘down(…)’ is null or not an object
Line: 603
Char: 9
Code: 0
URI: http://www.sparkfun.com/js/sparkfun.js
Message: ‘SFE’ is undefined
Line: 653
Char: 2
Code: 0
URI: http://www.sparkfun.com/search/results? … t=products
Line: 653
Char: 2
Code: 0
Line: 653
Char: 2
Code: 0
Line: 653
Char: 2
Code: 0
chaskins21:
Can’t add anything to the wish list.saw errors on this page in the corner.
Thanks for the heads up, this should be fixed with the next deploy. Check back later today.
http://www.sparkfun.com/commerce/present.php?p=HowFar seems to be broken.
followed from the
“Check out our comparative range test!” on this http://www.sparkfun.com/products/151 and other pages…
Chuck
“To invent, you need a good imagination and a pile of junk” – Thomas Alva Edison (1847-1931)
UAVGeek:
I’ll see if anyone knows what that’s supposed to be. ![]()
…got it. Supposed to redirect to http://www.sparkfun.com/tutorials/48 - fixed in description.
“Changing currency” function appears broken. Selecting currency other than USD has no effect.
Cheers,
Adrian
