Postcard portability shield mechanical issues
hi I am developing a product based on the postcard and portability shield.
The portability shield has a a couple of mechanical design issues.
The first is the lower edge of the screen is unsupported at the corners. I have destroyed one screen and damaged another. I have tried adding a glue support to the corners which helps a little. see photo.
two of my last portability shields arrived with the screen misaligned so the on off switch is almost impossible to use. maybe it needs a 3d printed jog for alignment? (photo)
The on off switch is almost useless and the location invites damage to the screen. please move it and improve it.
Maybe I am grumpy this morning as i noticed i had damaged the screen of yet another postcard. Its a great little dev tool.
Finally please continue to push Quectel on the acceleration issue of this SOC. i will try to get more data.
thanks
“jig” not jog…
Thanks for the feedback! These are worthwhile suggestions, I’ll pass them along :slight_smile:
Glue on the corners will not save you in the field. The shield is made for dev and demo, not to live inside a product. If you plan to sell this I would stop fixing the shield and do own small carrier board, screen held by the case, switch where you want it. In a small batch it costs less than broken screens and returns.
How many units is your first run? Under 50 I would maybe keep the shield plus a printed frame, above that own board pays back.
Thanks. Not for production just to get a few units into the field.
Ok, for few units in the field i would just print a frame that holds the lower edge of screen and covers the switch, so nobody pushes on glass. Cheap and one evening of work.
Where they go, indoor or outdoor/vehicle? Vibration kills this screens faster then fingers.
I agree that the shield could do with a redesign. I have two postcard+shield units that I use regularly. I love them, but… I designed a 3D printed case that allows me to just barely reach the power switch. However, it still leaves the switches and the display open to the elements. A design that provides protection and easier access to the power switch would be great.
Nice case LenS. So 3 of us now with same complaint, power switch and open display.
Easy trick for the switch: print small lever or pin in the case wall that pushes the switch from outside, then the opening can be tiny. For the display, thin clear PETG or acrylic window glued from inside, and some foam gasket around.
Do you use them outdoors most of time? If yes I think the real fix is switch moved to the edge in next shield revision, case only helps so much.
