Power a Pi from the 5V screw terminals of a pHat?
Can I use the pHat with the 5V screw terminals to power a raspberry Pi 3 B+ through the GPIO pins?
Thank you!
Are you asking about the pHat v2.0? https://www.sparkfun.com/products/15945
If so, yes, you should be able to. There is a current limiting fuse for .75A, so please keep that in mind.
I hope this helps point you in the right direction.
Yes that is the right pHat, and this does help thank you!
