Precision and stability of external 32.768kHz crystal of the DEV-13664
Hi all,
I would be interested if there is more detailed information availiable on the external 32.768kHz crystal of the DEV-13664.
The BOM only states: "32.768kHz: Various standard crystals. Proven footprints. "
Is there a list of alternative parts which are usually used for producing the DEV-13664, so that I could have a closer look into the data sheets and have further information on precision and drift?
Thank you and best regards…
This is the main one used https://abracon.com/Resonators/ABS07.pdf
