I had got some sample chips of LPC2142 from philips. I soldered it on a extension PCB. I have also got the USB J-Link from IAR. I connected the programming/debug port of the J-Link (10x2 Header) to the pins of the chip using a bread board. On the other side I connected the J-Link to the USB port of the PC and installed the proper driver. I ran the JLINK.exe application given by the J-Link provider. The application returned the OEM make and Serial number of the J-Link correctly. But it gave out a error message saying “No Target Chip Found”. Could any body suggest what could be the problem?
