So I’m another newb that tried the sparkfun tutorial http://www.sparkfun.com/commerce/presen … BEE-2-Code
and got stuck.
The first error I got was the device id mismatch. AVRdude detected device id=0x000102 and it refuses to program. I tried to override it with -F command and that didn’t help.
However, I played it with it some more and it looks like it’s not even responding any more. I get:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
As for process, I pretty much followed the tutorial except I used the 5V rail of a computer psu for my vcc (with the .1uf decoupling caps). And I made sure reset pin is high.
Any help is appreciated.
