Problem when my program write on my SD card. Have you idea?
i past the code and that a see on the serial monitor and that i have on my sd car
i just want past the value that you can see monitor in the file excel
an exemple is more expressive i suppose:
see pictures for anderstand more.
a part of program
while (1)
delay(5);
Serial.print(n,DEC);
Serial.print(“\t\t”);
bout << n;
n++;
temp2 = readval(TEMPERATURE); // Lireread regeiter of temperature value code complement A²
temp2=~temp2; // invert of the value
temp2++;// value +1
temp2=temp2&0x000000FF; // do maskavec 0x000000FF
temp2=278-temp2-7; convert kelvin to Celcuis
Serial.print(temp2,DEC);
bout << ‘;’ << temp2;
temp=readval(ACCXMSB);
temp2=temp << 8,temp2|=readval(ACCXLSB),temp2=temp2>>2,temp3=temp2*(0.00198);
Serial.print(“\t\t\t”);
Serial.print(temp3,5);
bout << ‘;’ << temp3;
temp=readval(ACCYMSB);
temp2=temp<<8,temp2|=readval(ACCYLSB),temp2=temp2>>2,temp3=temp2*(0.00198);
temp=readval(ACCZMSB);
temp2=temp<<8,temp2|=readval(ACCZLSB),temp2=temp2>>2,temp3=temp2*(0.00198);
Serial.println();
bout << endl;
logfile << buf; // log data
logfile.flush();// flush data to SD
i have found the solution of my probleme
it’s with this: obufstream bout(buf, sizeof(buf));
it’is not correctly place and the buffer and the size don’t arrive really to init themself correctly.
i show you that now that’s working correctly
But i have a last question how do you do to write number with more décimal.
you can see on png file acceleration Z 1.03; 1.02
and i want 1.02366 for example
if i founds before a reply i give the solution
think you for your good work for the site sparkfun, excelent good job sincerly.
hile (1)
delay(5);
obufstream bout(buf, sizeof(buf)); :mrgreen: // at the begining it is place out the fonction
bout << n;
n++;
temp2 = readval(TEMPERATURE); // Lire le registre de la temperature
temp2=~temp2;
temp2++;
temp2=temp2&0x000000FF; // faire un masque avec 0x000000FF
temp2=278-temp2-7;
Serial.println();
bout << endl;
