i am using EM406-A module for my telemetry project.it was working fine till yesterday but due 2 some problem in my DC adapter some extra voltages were given through VCC
now it is not working ,its led is still blink as i connect it in my circuit bt not as shiningly as it was and has become Dim and there is no information through the Tx pin
yes i will definetly prevent this frm happening again bt i jst want 2 know that is it ok becoz i m not receiving anything through Tx but LED is on but is dim jst the same as it glows in its starts
or in other words does EM-406A has a built in voltage regulator
Such modules often have internal regulators, but some circuitry might be unregulated. I doubt if it can be repaired economically if you put too high a voltage into it.
is there no built in voltage regulator in EM-406A ???
How would we know? All we can tell you is what's in the datasheet or we can see on the PCB.
Even if there was a regulator, its probably buried under the metal casing and is a very fine pitch component, do you really think if it exists, you can replace it?
Get a new one, learn from your mistakes, that’s what this hobby is about.
