-d3 output with STM32F101C6 when set breakpoint at 0x080003D2:
Debug: 3218 35891 gdb_server.c:1866 gdb_input_inner(): received packet: 'm80003d2,2'
Debug: 3219 35891 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x080003d2, len: 0x00000002
Debug: 3220 35891 target.c:1063 target_read_buffer(): reading buffer of 2 byte at 0x080003d2
Debug: 3221 35891 gdb_server.c:1866 gdb_input_inner(): received packet: 'M80003d2,2:55aa'
Debug: 3222 35891 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x080003d2, len: 0x00000002
Debug: 3223 35891 target.c:994 target_write_buffer(): writing buffer of 2 byte at 0x080003d2
Debug: 3224 35906 gdb_server.c:1866 gdb_input_inner(): received packet: 'm80003d2,2'
Debug: 3225 35906 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x080003d2, len: 0x00000002
Debug: 3226 35906 target.c:1063 target_read_buffer(): reading buffer of 2 byte at 0x080003d2
Debug: 3227 35906 gdb_server.c:1866 gdb_input_inner(): received packet: 'M80003d2,2:00f0'
Debug: 3228 35906 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x080003d2, len: 0x00000002
Debug: 3229 35906 target.c:994 target_write_buffer(): writing buffer of 2 byte at 0x080003d2
Debug: 3230 35906 gdb_server.c:1866 gdb_input_inner(): received packet: 'Z1,80003d2,2'
Debug: 3231 35906 gdb_server.c:1242 gdb_breakpoint_watchpoint_packet(): -
Debug: 3232 35906 target.c:1253 target_write_u32(): address: 0xe0002010, value: 0x880003d1
Debug: 3233 35906 cortex_m3.c:828 cortex_m3_set_breakpoint(): fpc_num 2 fpcr_value 0x880003d1
Debug: 3234 35906 breakpoints.c:95 breakpoint_add(): added hardware breakpoint at 0x080003d2 of l
Debug: 3235 35906 gdb_server.c:1866 gdb_input_inner(): received packet: 'me0002000,4'
Debug: 3236 35906 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0xe0002000, len: 0x00000004
Debug: 3237 35906 target.c:1063 target_read_buffer(): reading buffer of 4 byte at 0xe0002000
Debug: 3238 35906 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002000,4:02000000'
Debug: 3239 35906 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002000, len: 0x00000004
Debug: 3240 35906 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002000
Debug: 3241 35922 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002008,4:d1030088'
Debug: 3242 35922 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002008, len: 0x00000004
Debug: 3243 35922 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002008
Debug: 3244 35922 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me000200c,4:f5030088'
Debug: 3245 35922 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe000200c, len: 0x00000004
Debug: 3246 35922 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe000200c
Debug: 3247 35922 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002010,4:fd030088'
Debug: 3248 35922 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002010, len: 0x00000004
Debug: 3249 35922 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002010
Debug: 3250 35922 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002014,4:00000000'
Debug: 3251 35922 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002014, len: 0x00000004
Debug: 3252 35922 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002014
Debug: 3253 35922 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002018,4:00000000'
Debug: 3254 35922 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002018, len: 0x00000004
Debug: 3255 35922 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002018
Debug: 3256 35938 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me000201c,4:00000000'
Debug: 3257 35938 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe000201c, len: 0x00000004
Debug: 3258 35938 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe000201c
Debug: 3259 35938 gdb_server.c:1866 gdb_input_inner(): received packet: 'Me0002000,4:03000000'
Debug: 3260 35938 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0xe0002000, len: 0x00000004
Debug: 3261 35938 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0xe0002000
-d3 output with LPC2148 when set breakpoint at 0x00002122 in Thumb Mode:
Debug: 4111 37422 gdb_server.c:1866 gdb_input_inner(): received packet: 'm2122,2'
Debug: 4112 37422 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x00002122, len: 0x00000002
Debug: 4113 37422 target.c:1063 target_read_buffer(): reading buffer of 2 byte at 0x00002122
Debug: 4114 37422 arm7_9_common.c:1830 arm7_9_read_memory(): address: 0x00002122, size: 0x00000002, count: 0x00000001
Debug: 4115 37422 gdb_server.c:1866 gdb_input_inner(): received packet: 'M2122,2:55aa'
Debug: 4116 37422 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x00002122, len: 0x00000002
Debug: 4117 37422 target.c:994 target_write_buffer(): writing buffer of 2 byte at 0x00002122
Debug: 4118 37422 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 4119 37437 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Warning: 4120 37437 arm7_9_common.c:2125 arm7_9_write_memory(): memory write caused data abort (address: 0x00002122, size: 0x2, count: 0x1)
Debug: 4121 37437 arm7tdmi.c:475 arm7tdmi_write_xpsr_im8(): xpsr_im: df, rot: 0, spsr: 0
Debug: 4122 37437 gdb_server.c:1866 gdb_input_inner(): received packet: 'm2122,2'
Debug: 4123 37437 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x00002122, len: 0x00000002
Debug: 4124 37437 target.c:1063 target_read_buffer(): reading buffer of 2 byte at 0x00002122
Debug: 4125 37437 arm7_9_common.c:1830 arm7_9_read_memory(): address: 0x00002122, size: 0x00000002, count: 0x00000001
Debug: 4126 37437 gdb_server.c:1866 gdb_input_inner(): received packet: 'M2122,2:304a'
Debug: 4127 37437 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x00002122, len: 0x00000002
Debug: 4128 37437 target.c:994 target_write_buffer(): writing buffer of 2 byte at 0x00002122
Debug: 4129 37437 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 4130 37437 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Warning: 4131 37453 arm7_9_common.c:2125 arm7_9_write_memory(): memory write caused data abort (address: 0x00002122, size: 0x2, count: 0x1)
Debug: 4132 37453 arm7tdmi.c:475 arm7tdmi_write_xpsr_im8(): xpsr_im: df, rot: 0, spsr: 0
Debug: 4133 37453 gdb_server.c:1866 gdb_input_inner(): received packet: 'Z1,2122,2'
Debug: 4134 37453 gdb_server.c:1242 gdb_breakpoint_watchpoint_packet(): -
Debug: 4135 37453 breakpoints.c:95 breakpoint_add(): added hardware breakpoint at 0x00002122 of length 0x00000002
-d3 output with LPC2148 when set breakpoint at 0x000033C8 in ARM Mode:
Debug: 4563 33812 gdb_server.c:1866 gdb_input_inner(): received packet: 'm33c8,4'
Debug: 4564 33812 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x000033c8, len: 0x00000004
Debug: 4565 33812 target.c:1063 target_read_buffer(): reading buffer of 4 byte at 0x000033c8
Debug: 4566 33812 arm7_9_common.c:1830 arm7_9_read_memory(): address: 0x000033c8, size: 0x00000004, count: 0x00000001
Debug: 4567 33812 gdb_server.c:1866 gdb_input_inner(): received packet: 'M33c8,4:55aacc33'
Debug: 4568 33812 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x000033c8, len: 0x00000004
Debug: 4569 33812 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0x000033c8
Debug: 4570 33812 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 4571 33828 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Warning: 4572 33828 arm7_9_common.c:2125 arm7_9_write_memory(): memory write caused data abort (address: 0x000033c8, size: 0x4, count: 0x1)
Debug: 4573 33828 arm7tdmi.c:475 arm7tdmi_write_xpsr_im8(): xpsr_im: df, rot: 0, spsr: 0
Debug: 4574 33828 gdb_server.c:1866 gdb_input_inner(): received packet: 'm33c8,4'
Debug: 4575 33828 gdb_server.c:1049 gdb_read_memory_packet(): addr: 0x000033c8, len: 0x00000004
Debug: 4576 33828 target.c:1063 target_read_buffer(): reading buffer of 4 byte at 0x000033c8
Debug: 4577 33828 arm7_9_common.c:1830 arm7_9_read_memory(): address: 0x000033c8, size: 0x00000004, count: 0x00000001
Debug: 4578 33828 gdb_server.c:1866 gdb_input_inner(): received packet: 'M33c8,4:50219fe5'
Debug: 4579 33828 gdb_server.c:1129 gdb_write_memory_packet(): addr: 0x000033c8, len: 0x00000004
Debug: 4580 33828 target.c:994 target_write_buffer(): writing buffer of 4 byte at 0x000033c8
Debug: 4581 33828 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000004
Debug: 4582 33828 embeddedice.c:397 embeddedice_write_reg(): 0: 0x00000005
Warning: 4583 33843 arm7_9_common.c:2125 arm7_9_write_memory(): memory write caused data abort (address: 0x000033c8, size: 0x4, count: 0x1)
Debug: 4584 33843 arm7tdmi.c:475 arm7tdmi_write_xpsr_im8(): xpsr_im: df, rot: 0, spsr: 0
Debug: 4585 33843 gdb_server.c:1866 gdb_input_inner(): received packet: 'Z1,33c8,4'
Debug: 4586 33843 gdb_server.c:1242 gdb_breakpoint_watchpoint_packet(): -
Debug: 4587 33843 breakpoints.c:95 breakpoint_add(): added hardware breakpoint at 0x000033c8 of length 0x00000004
