Open On-Chip Debugger 0.5.0-dev (2010-06-17-21:25)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
1000 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
Info : clock speed 1000 kHz
Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: stm32.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Warn : Unexpected idcode after end of chain: 64 0x00000ff0
Warn : Unexpected idcode after end of chain: 96 0x00000ff0
Warn : Unexpected idcode after end of chain: 128 0x00000ff0
Warn : Unexpected idcode after end of chain: 160 0x00000ff0
Warn : Unexpected idcode after end of chain: 192 0x00000ff0
Warn : Unexpected idcode after end of chain: 224 0x00000ff0
Warn : Unexpected idcode after end of chain: 256 0x00000ff0
Warn : Unexpected idcode after end of chain: 288 0x00000ff0
Warn : Unexpected idcode after end of chain: 320 0x00000ff0
Warn : Unexpected idcode after end of chain: 352 0x00000ff0
Warn : Unexpected idcode after end of chain: 384 0x00000ff0
Warn : Unexpected idcode after end of chain: 416 0x00000ff0
Warn : Unexpected idcode after end of chain: 448 0x00000ff0
Warn : Unexpected idcode after end of chain: 480 0x00000ff0
Warn : Unexpected idcode after end of chain: 512 0x00000ff0
Warn : Unexpected idcode after end of chain: 544 0x00000ff0
Warn : Unexpected idcode after end of chain: 576 0x00000ff0
Warn : Unexpected idcode after end of chain: 608 0x00000ff0
Error: double-check your JTAG setup (interface, speed, missing TAPs, …)
Command handler execution failed
in procedure ‘jtag’ called at file “command.c”, line 654
called at file “command.c”, line 365
Warn : jtag initialization failed; try ‘jtag init’ again.
error: -100
in procedure ‘script’ called at file “command.c”, line 654
called at file “embedded:startup.tcl”, line 57
in procedure ‘reset’ called at file “openocd.cfg”, line 15
This shows that the target CPU can respond to the JTag dongle, but still doesn’t give the expected response.
