Following the hookup guide I soldered the header pins to the Qwiic Shield for Arduino and then plugged it into a SparkFun RedBoard. Here are few pictures:
The BNO080 breakout was connected to the Qwiic Shield with a Qwiic cable
The BNO080 library was installed using Arduino library manager.
Arduino version: 1.8.13
With this setup, I started to try the first example - Example1-RotationVector (loaded from File > Examples > SparkFun BNO080 Cortex Based IMU), but I got: "BNO080 Read Example
BNO080 not detected at default I2C address. Check your jumpers and the hookup guide. Freezing…" in the serial monitor.
How can I fix it?
Thanks much,
-Qiang
