Hello all,
I couldn’t get the MP3 Trigger to work the way I wanted so I purchased the Proximity Sensing Kit with audio.
Physical connections were easy enough, but now I am stuck on the coding. I’ll admit I’ve never coded before. I am following the “Yack O Lantern setup guide” as my example and Im stuck at the coding. Where do I start? Is there a program I need to use to make this work?
Basically I want Track001 on my memory card to play anytime motion is detected. Then I want to make the motion sensor as sensitive as possible. Can anyone point a noob in the right direction?
