PW10ACE y HX711 Sparkfun
Hello, you know, I bought an HX711 from the Sparkfun brand but I have had problems connecting it to my Arduino mega. I cannot make it read weight with a PW10ACE load cell. The values it gives me are 2681109.00 g when it should be 0.00 and the connections and I have tried more. 3 times
the first time was
E+ = GREEN
E- = LEAD
A- = WHITE
A+ = RED
B- = BLACK
B+ = BLUE
the second time was
E+ = BLUE
E- = BLACK
A+ = WHITE
A- = RED
and the third time was
E+ = BLUE
E- = BLACK
A+ = WHITE
A- = RED
B- = GREEN
B+ = LEAD
and at one point I thought it was the load cell but I used a normal HX711 and it was fine and then I thought it could be the Sparkfun HX711 and I used another one and it didn’t work either
This appears to be the datasheet for your load cell.
https://loadcell.ae/Datasheets/HBM-PW10A.pdf
The wire colors are as you recorded ‘the second time.’
Make sure your sense wires (green & gray) are not shorting to any other wires or each other.
The sense lines parallel the excite wires and would be used to carry the excitation voltage back to the instrument.
