Setup:
- Sparkfun product #GPS-21305, ZED-F9R Pi Hat
- Dual-band antenna
- Raspberry Pi 3B
- Raspberry Pi OS Bookworm (2024-03)
- Python 3.11.2
Expected behavior:
- Install ublox_gps module on MCU.
- Run example script geo_coords_ex1.py
- Geographic coordinates plus compass heading are shown in terminal.
Actual behavior:
- Install dependencies as listed above.
- Run script repeatedly and wait for it to finish.
- See no values (but instead an error “geo has no attribute ‘lat’” or similar) in terminal most times, but some times there are coordinate and heading values.
Troubleshooting:
- Run the script back-to-back multiple times. The rate of return for values seems to be ~20%.
- Wait for the board to warm up (~4 minutes) before running the script. No change noted.
- Modify the “timeout” value on port initialization. No change noted from 0.1 to 10 in steps of 1.
- Modify the baud rate: 9600, 38400, and 115200 in both board and script. No change noted.
- Move the antenna and board around. No change noted.
- Move the antenna and board to a different location. Various places were attempted, no change was noted.
- Check the board in U-Center. All values are present, reasonable, and updating at 1 Hz in U-Center.
- Check UART settings in U-Center. The UART1 port was confirmed to be open and sending data out. It was configured to send UBX messages out.
Request:
Did I miss a setup step or adjustment that keeps the example #1 for the Python library from functioning all the time, every time? What should I check or do next?
You most likely have a python pkg issue similar to this python - Geoviews Attribute error: module 'geoviews' has no attribute 'output' - Geographic Information Systems Stack Exchange and that a usable variable is being passed (un-assign any ‘none’ location/at settings and ensure you are testing outside with a clear view of the sky)
Also ensure you have a working qwiic python pkg installed too…finally, it might help to run an older/different OS on a 3B+, especially if you end up needing to run other older/deprecated pkgs
Thank you for the response, @TS-Russell. Actions and follow-up have been made.
The “sparkfun-qwiic-i2c” and “sparkfun-qwiic” packages have now been installed on Raspberry Pi OS 11, Bullseye, on a Pi 3B (not B+).
Checking the piwheels project, this seems to be the latest version. However, the Release table on that site showed a failed build for all Pi OS versions of package version 1.1.5, so the package was reinstalled with version 1.1.4 (the next package version with successful builds.)
Follow-up:
- The link given above Geoviews seemed to point to a root issue of a python package not being installed at its most recent version. Was this intended? The version of “sparkfun-ublox-gps” installed was 1.1.5.
- After the reinstall of the “sparkfun-ublox-gps” package version 1.1.4, the “geo_coords_ex.py” script gets hung up on the “geo = gps.geo_coords()” line. The method is called, but it never returns and the script cannot advance. I suspect an infinite loop but have no way to check that guess. U-Center confirms that data is still being sent out over the UART1 port to the Pi Hat. Is this an expected behavior of v1.1.4 to wait until there is a message to return? Do I need to match to a specific version of the Qwiic packages?
- For the suggestion of “un-assign any ‘none’ location/at settings,” where would I check that/those settings?
