Queries
Hi All,
I am pretty new to XSCALE Development. I would like to port U-BOOT and Linux to PXA255 Processor and gain the knowledge of full OS porting.
I would like to clarify certain things.
  • Will OLIMEX ARM-USB-TINY will be compatible with PXA255
  • Is it possible to do debug any code using PXA255 + ARM-USB-TINY+OCD combination
  • Is it posssible to do U-BOOT and Linux-Kernel level debugging using the same combination
  • Looking at the JTAG interface pins of the OLIMEX ARM-USB-TINY found that pin 2 is connected with VREF across a R45 resistor, but this pin is left open in my target board, will it still work.
  • Also pin 11 is left open, will still work
Please clarify my doub’ts
Thanks & Regards,
Senthil.
