Hi All!
I’m a mechanical engineer, a novice in microcontrollers.
Be gentile ![]()
I have an embedded machine I’m trying to log information from. The embedded machine outputs a USB-C connection, sending out serial communication (currently I’m reading it with TeraTerm). I have purchased the Logging Shield without noticing I need a Thing Plus board to mount it on.
After understanding the mistake I’ve made, I wanted to be extra sure that’s the only component missing.
And this is where I’m confused -
It is not clear from the hookup guide whether I can connect my embedded machine directly to the Logging Shield or if I should convert the data from the embedded machine into serial communication first using the FT231X Breakout board (BOB-13263)?
Thanks in advance to all responders!
